Old 07-06-2015, 06:40 AM   #1
solort
Drives: Series 10 FRS
How hard to make a bolt on axle back track pipe?
How hard is it to make a track pipe like the nameless? What size exhaust flange and what angle is the tip to line up with driver exhaust outlet? Do you use 2.5 tubing or can you use larger so if you do not get a mandrel bend you will compensate for inside diameter flow? Thx for any suggestions or if you have one for sale please pm me.
solort is offline   Reply With Quote
Old 07-06-2015, 07:01 AM   #2
swarb
not hard if you know how to weld.
2.5 inch, angle is different depending on where the bend is.
2.5 inch, mandrel won't make much difference.
exhaust shop or buy one.
Old 07-06-2015, 08:18 AM   #3
Chad11491
Drives: 85.5 Porsche 944, '15 mustang GT PP
An exhaust shop should be able to build you a single exit muffler delete (I guess what you're asking) for pretty cheap. The name brand exhaust prices for this chassis are pretty overprice IMO.
Chad11491 is offline   Reply With Quote
Old 07-07-2015, 10:09 AM   #4
onzippy
Drives: 2014 FRS
I did one on Sunday. Had enough stuff around so cost of zero $.
Hard part was making the flange but maybe you can buy one when you get the pipe.
-Mount the flange
-Slash cut 2 1/2" pipe at ~28degrees.
-Hold slash cut to flange rotate as needed.
-Tack, remove, weld, install.
It got heavy when I added the fancy fancy tip so I later added a 1/2 rod to hang from one of the rubber mounts.
Didn't even jack up the car.
onzippy is offline   Reply With Quote
WTB axle back straight track pipe solort Want-To-Buy Requests 4 07-01-2015 11:20 PM
Axle back exhaust feed back requested Gruppe-s Engine, Exhaust, Transmission 10 12-10-2014 07:56 PM
Nameless axle back or front pipe/over pipe in SoCal kevin.nguyen Engine, Exhaust, Transmission 0 07-30-2014 10:04 PM
MI: FS: FRS BRZ Greddy SP Elite Axle Back and DC Sport Front Pipe Bao Engine, Exhaust, Bolt-Ons 0 07-23-2014 11:03 AM
Possible trade? Nameless axle-back for Perrin Resonated Cat-back GTB/ZR-1 Engine, Exhaust, Bolt-Ons 0 03-26-2013 01:51 PM
