Old 07-06-2015, 02:59 AM   #1
F3RGY68
F3RGY68's Avatar
Drives: FR-S 10 Series MT, Honda 919
Wire Dash Lighting
Ok so my EL dash has never worked in my 10 series. I'm looking at wiring in my own basic lighting with 2 wires, and would like the least invasive route. The existing wiring for the panel basically consists of the switch, controller, and EL panel. There's 3 potential reasons why it doesn't work in the first place. So, I would greatly appreciate anyone willing to advise the easiest, least invasive wiring.
-Try to wire to switch using existing wiring
-If that doesn't work, wire straight power/ground to be always on.
Specifics would be fantastic, and trying to use existing connectors to avoid splicing. Here's a schematic:
F3RGY68 is offline   Reply With Quote
Old 07-08-2015, 03:36 AM   #2
BlackCaGuy
Drives: 2013 Scion FR-S Series 10
Try cool under the kneeboard under the steering wheel. There's a flip switch which controls the lighted dash. It might just be switched off. Sit down, place your hand between your leg and the steering column. I found out that the dealership didn't even know about it.
BlackCaGuy is offline   Reply With Quote
Old 07-09-2015, 10:37 PM   #3
F3RGY68
F3RGY68's Avatar
Have flipped switch on several occasions; after disconnecting battery, flashing with OFT. My dealership looked at the book and did the same. They then told me it would take a full day to take the dash apart and I would have to leave it overnight, and they would not provide a rental.
Here's what they really said: We don't know anything about the feature, and it's not worth our time and effort.
Old 11-08-2015, 11:53 PM   #4
eldevil
eldevil's Avatar
Drives: 2013 FR-S 10 Series 477 of 2500
same here
i'm having the same problem
eldevil is offline   Reply With Quote
Old 07-06-2020, 08:59 PM   #5
Frito
Drives: Scion frs 10 series
Has anyone figured what fuse it's connected to in case it's a fuse burn out?
Frito is offline   Reply With Quote
Old 05-05-2023, 11:34 AM   #6
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
Fuses for this system are behind the radio. Mine has been dead for a few years now and I am working making my own controller for the system.
projek_01 is offline   Reply With Quote
Lighting Tech 101: Research Automotive Lighting Technology Diode Dynamics Announcements, Contests, Giveaways 44 08-30-2018 01:17 PM
WTT: 2013 FRS Interior Dash Panels for BRZ Silver dash panels DCStorm Interior Parts (Incl. Lighting) 10 03-27-2015 03:04 PM
Help me identify this wire! Extra wire around battery after clutch job YouShallKnow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 12-09-2014 03:04 PM
Reverse Wire Tap wire Location? Norkoastal Electronics | Audio | NAV | Infotainment 2 10-19-2012 11:22 AM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 11:06 PM
