Old 07-05-2015, 05:27 AM   #1
BRZUK
Drives: GT86
PKEASE HELP
Hi Guys, ( I also postd this in the general BRZ forum as im freaking out )
I had a supercharger fitted and picked the car up yesterday, 2 hours into driving the car the check engine light came on with the traction control light so i pulled over and turned the car of and on the traction light with off but the checky engine stayed on, the car was ticking over perfectly.
I dissconnected the battery and reconnected after 2 minites or so and all was clear so i started the driving again as i needed to catch a boat home. 350-400 miles later on my drive it happened and i did the same disconnected the battery, when home i couldnt read any codes due to reseting the ECU, i also cany get a hold of the company/ tuner of the install.
What could this be? what would you do ? Please help Guys
Thank you.
BRZUK is offline   Reply With Quote
Old 07-05-2015, 05:32 AM   #2
FirestormFRS
Without codes no one knows. I wouldn't worry too much if it reset and the car runs fine other than the CEL.
FirestormFRS is offline   Reply With Quote
Old 07-05-2015, 05:55 AM   #3
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Drive it for 40miles or so and rerun codes
Packofcrows is offline   Reply With Quote
Old 07-05-2015, 09:16 AM   #4
BRZUK
Drives: GT86
ill give it ago thank you
Old 07-05-2015, 11:01 AM   #5
extrashaky
Drives: 2014 BRZ Limited
Car's totaled. Bummer.
Old 07-05-2015, 12:16 PM   #6
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
part out time!
Old 07-05-2015, 12:37 PM   #7
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
If you got a CEL and the car is still working fine, that's because you probably can't damage it by driving.
If the ECU see a potential damage, it will turn down the power or revs and make the CEL flash.
If you got a simple CEL, you can drive to the shop to have the car check.
MaximeT is offline   Reply With Quote
Old 07-05-2015, 12:45 PM   #8
stugray
Drives: 2013 GBS BRZ Limited
SWAG (again) you lost a coil pack, Ignition throws a code, and disables your traction control.
Stop at a Auto Parts store, borrow their OBD reader and read the code.
Old 07-05-2015, 01:30 PM   #9
Tromatic
A OBD dongle and something like Carista should be a must-have for a FI car. Somebody here a while ago was getting CEL's and ignored them. Don't recall if his insurance paid out for the total or not.
Tromatic is offline   Reply With Quote
Old 07-05-2015, 01:50 PM   #10
Cal3000
Drives: Panda FR-S
I bet you anything you have a P0451 code for the evap. Sounds like the same exact condition I had a while back after I got a tune. If that's the case, you are good.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 07-05-2015, 03:04 PM   #11
BRZUK
Drives: GT86
I took it to a shop and all they could see was lost communication with various things like ECU, power windows, traction control, the codes are C1201,U0100,U0155
Old 07-05-2015, 03:08 PM   #12
MaximeT
MaximeT's Avatar
You may have add some codes with battery disconnection.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
Old 07-05-2015, 03:13 PM   #13
BRZUK
Drives: GT86
Thats what im thinking but we couldent see what the reason was for the first CEL, can disconnecting the battery wipes the codes ?
Old 07-05-2015, 03:16 PM   #14
MaximeT
MaximeT's Avatar
I'm not sure about that. You should drive until you get the CEL and read the codes again.
