Old 07-02-2015, 10:59 AM   #1
kilohercas
Drives: Subaru BRZ (soon?)
Subaru BRZ 2015 Series Blue rebuild
Hello,
For quite some time i was searching in IAAI/Copart Subaru BRZ that could be restored at the same cost, or lower than i can buy locally.
In may, at Copart website Subaru BRZ Series blue car showed-up, and i had to buy it. This corresponded to my birthday, so good present for myself
This car suffered from some bad driver (lot of beer cans everywhere) hitting the pole or something, right side is a bit smashed, but engine and electronics works.
So the good:
Engine works, back side is ok, but bumper needs repainting due to large scratch. Interior is mint, i only have to fix airbag and seat belts, since they are retraced and locked.
The bad:
For some reason, i can't put inti even gear (2,4,6), i tested 1 3 5 R, all in great working order, it looks like i simply can't push it in, like something is jammed. But no sounds for odd gears. Any idea why ?
The Ugly:
As i stated before, right side is damaged, and it looks like i have some shift in geometry. i will need bumper, STI Lip, STI rim, lower control arm for right side, ABS sensor, stabilizer, and some metal work at that corner. hood is also mangled, and when i fit new one i have at least 2-3mm misalignment ( hood is overlapping with wing around 2mm
As usual, if some one have parts i need, write me a message :-)
Here is some photos:
kilohercas is offline   Reply With Quote
Old 07-02-2015, 11:47 AM   #2
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
damn, i love seeing threads like this!
good luck!
Old 07-03-2015, 01:03 PM   #3
P3tras
Drives: Subaru BRZ '13 WRB
Get er dunnnn. Good luck!
P3tras is offline   Reply With Quote
Old 07-03-2015, 02:02 PM   #4
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Good luck! I hope you have time to keep us updated on your progress!
aegisdrgn is offline   Reply With Quote
Old 07-03-2015, 02:24 PM   #5
kilohercas
Thank you all, i will update this thread as something interesting is happening. Right now getting parts for right corner so i can send it for geometry correction. And i will be pulling gearbox (somehow) because i have no idea why i can't use even gears:
Old 07-04-2015, 02:32 PM   #6
kilohercas
today i have some free time so i started to pull gearbox, because even gears was missing. When i started to remove bolts, i noticed that something is wrong with gearbox support. And yes, sure enough it was bend quite badly.
So i have to remove middle exhaust section ( catalytic converter ) , lot of screws, and finally support from gearbox. Here is how it looks, and video of gearbox action after i supported it by hydraulic jack:
[ame="https://www.youtube.com/watch?v=noaSAFLDNKY"]Subaru brz gearbox fix - YouTube[/ame]
So next, getting this part, and putting it to place, and bolting exhaust system, and some heat shields
Old 07-06-2015, 01:13 AM   #7
aegisdrgn
aegisdrgn's Avatar
That's great! Hopefully there isn't any damage to the transmission internals - having the "center support bearing bracket" twist that much is indicative of extremely strong forces acting on the transmission.
Old 07-06-2015, 04:40 AM   #8
kilohercas
Well,yes and no. Since engine and gearbox are suspended on rubber supports, this part was specially designed for gearbox to move under acceleration. Due nature of stooping car by using street lamp, gearbox with engine is huge mass, and it moves with a lot of force. so after rubber support reached safe limit, it will start to bend stuff, so this is what happened here.
Old 07-06-2015, 10:05 PM   #9
simonweisberg
Drives: 2013 Subaru BRZ
Probably works better than the Stoptech or Brembo BBK!
simonweisberg is offline   Reply With Quote
Old 07-10-2015, 07:43 AM   #10
kilohercas
Does any one know how i can found metal sheet's codes that was damaged ? somehow i can find it
basically i need right side metal work, it looks like 3 stamped metal panels
One that goes from energy absorber, one that raps around suspension mount, and one that surrounds lamp assembly
Old 07-10-2015, 08:19 AM   #11
adamg
Drives: brz
Wow Good luck!
adamg is offline   Reply With Quote
Old 07-10-2015, 03:42 PM   #12
TurboBRZ
TurboBRZ's Avatar
Drives: 2013 BRZ Limited
Best of luck on the rebuild! I couldn't pass up my Blue BRZ either - got it from IAA.
Was there any other frame damage to go along with that apron damage? I knew my apron was a little messed up (so I thought) and after I got it all back together and brought into the frame shop it had to be adjusted downwards and outwards almost .5" with the firewall.
Do you have a tram gauge to measure your frame points with?
The BlueBaru Turbo Rebuild: http://www.ft86club.com/forums/showthread.php?t=90382
I Rebuild BRZ's for Breakfast.
TurboBRZ is offline   Reply With Quote
Old 07-10-2015, 04:03 PM   #13
BlueSky
BlueSky's Avatar
Drives: 2015 Aozora BRZ
Can't wait for more
BlueSky is offline   Reply With Quote
Old 07-12-2015, 03:14 AM   #14
kilohercas
Very nice job TurboBRZ, i wish i could have more space and tools in my garage to do this kind of work and skills too ! . Right now i can only do simple stuff.
It is very hard to say how much i have shift in geometry. If not 3mm step at driver side wing compared to driver-side door, i would say where is no shift, because it is hard to see difference like that, and i don't have idea how to do the measurement
Energy absorber was hit near support, so it redirected collision object to front right wheel, and thus mush shifter rails a bit to to left side, that why i have step between doors and wing i think. Here is some photos
I am also preparing to paint exhaust system in black heat resistant paint, i don't know will it do much good, but it should give some extra life for exhaust system, to to salt in winter. I will paint muffler part, cat part and some heat shields where is not splash protection panels. Small portion of exhaust near the engine is already covered, so i leave it as it is.
2015 Subaru BRZ STI Series Blue Build cameronjones239 Member's Car Journals 55 01-04-2017 03:03 PM
SON1C v3 -> 2015 Subaru BRZ Series Blue Build SON1C Member's Car Journals 15 06-26-2016 12:13 PM
FS: 2015 Subaru BRZ Series.Blue subieshanerz Cars for Sale/Trade 10 03-21-2015 04:35 AM
2015 subaru brz series blue 3 k miles sokol Cars for Sale/Trade 39 02-27-2015 11:32 PM
New Owner - 2015 Subaru BRZ Series.Blue R N M BRZ First-Gen (2012+) — General Topics 19 10-02-2014 10:35 PM
