Old 06-25-2015, 03:01 PM   #1
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Anyone with a built motor whats you catch can setup?
Curious what others are running. About to pull the trigger on the radium dual catch can.
Darryljr11 is offline   Reply With Quote
Old 06-25-2015, 03:48 PM   #2
s30series
Drives: 2015 BRZ Series.Blue
ive got the mishimoto....does a pretty good job. after 2k miles ive got a good build up of oil
s30series is offline   Reply With Quote
Old 06-25-2015, 04:10 PM   #3
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
I run the radium dual catch cans on N/A. PCV side collects crap. The driver side doesn't because I'm not boosted. I initially had plans to but never got around to it.
Radium setup is extremely solid.
2016 Camaro SS is offline   Reply With Quote
Old 06-25-2015, 04:36 PM   #4
OkieSnuffBox
Drives: '23 BRZ Limited
SO if you're planning on staying N/A, only worry about getting the PCV side?
Old 06-25-2015, 08:26 PM   #5
celek
Resident Gear Head
celek's Avatar
I am looking at the @racerx1715 setup for when I am done.
http://racerxfabrication.com/frs-brz...stem/catch-can
celek is offline   Reply With Quote
Old 06-25-2015, 11:15 PM   #6
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Drilled out pcv fitting on the block to vent to atmosphere can, fitting under ac compressor to vent to atmosphere can.
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 06-26-2015, 06:03 AM   #7
2016 Camaro SS
Drives: Fast
Probably the most beneficial.
Old 06-26-2015, 06:52 AM   #8
FRS Justin
Drives: 2013 Asphalt FRS
DO IT Radium is Awesome
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 06-26-2015, 08:24 AM   #9
LS1M
Drives: 2015 BRZ
Yes, Radium is awesome. Very high quality, tuck in nicely in the corners if the engine bay so they won't interfere with turbo or blowers., mount using all stock holes. They even have dip sticks so you can check the oil level. I just installed mine a couple of weeks ago. Expensive but worth it!
LS1M is offline   Reply With Quote
Who has a built motor? Fabron757 Forced Induction 77 11-19-2020 10:04 PM
10.5:1 Built Motor. alexisfire02 Engine, Exhaust, Bolt-Ons 16 03-24-2015 10:06 AM
what oil for BUILT MOTOR BOOSTED FA20 charged86 Engine, Exhaust, Transmission 7 02-19-2014 02:25 AM
which built motor? Fabron757 Forced Induction 82 11-26-2013 10:08 AM
Built motor over 600hp Fabron757 Forced Induction 19 11-02-2013 04:54 PM
