Old 06-23-2015, 10:31 AM   #1
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
Exclamation TRD exhaust owners - Warning! - READ!
After owning my TRD exhaust for 2 years I have discovered a problem with it. The exhaust note changed recently so I decided to do a little poking around. My car had the exhaust installed at delivery and it has ~50000km on it. Here is a video I took with my inspection scope (sorry for the crappy quality)
[ame="https://www.youtube.com/watch?v=jtaE_b7a71o"]Inside my TRD exhaust. June 23rd, 2015. - YouTube[/ame]
The resonator is all broken up inside and is partially blocking the exhaust. There is only one MINOR scratch on the exterior of the resonator so this was not caused by misuse or impact. I have thought about going through the warranty process but I will be making a custom mid-pipe instead to get rid of the 2" section. Details on the upgrade with a sound comparison to come.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
The Following User Says Thank You to Thorpedo For This Useful Post:
drewbot (06-23-2015)
Old 06-23-2015, 10:37 AM   #2
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Nice investigation.
venturaII is offline   Reply With Quote
The Following User Says Thank You to venturaII For This Useful Post:
Thorpedo (06-23-2015)
Old 06-23-2015, 10:44 AM   #3
celek
Resident Gear Head
celek's Avatar
not broken, its 2 pieces of perforated steel as an inner tube, wrapped around it is fiberglass to deaden sound. the note has changed over time because the fiberglass has broken down, absorbed moisture and filled with carbon
celek is offline   Reply With Quote
Old 06-23-2015, 10:46 AM   #4
Thorpedo
The SquadWhisperer
Good observations, captain obvious. I am well aware that the note changes over time due to what you listed, but sudden, noticable changes are not from that effect. Did you even watch the video? If you did, are you half blind? It literally rattles when I shake it around.
Old 06-23-2015, 11:47 AM   #5
celek
Resident Gear Head
celek's Avatar
Yeah I watched it, but at work with no sound
Old 06-23-2015, 11:55 AM   #6
Thorpedo
The SquadWhisperer
My inspection scope doesn't record sound but I've got it cut apart now. I'll post more pics and whatnot. It is definitely broken inside.
celek (06-23-2015)
Old 06-23-2015, 11:56 AM   #7
Teseo
Drives: frs
Time for a new aftermarket catback
Teseo is online now   Reply With Quote
Old 06-23-2015, 12:06 PM   #8
etherdude
Drives: 2020 Hakone Edition, 2015 FR-S
I had the TRD installed when I bought my 2015 FRS, but kept the original mid-pipe and exhaust. I figured that when the resonator dies, I will just have the stock mid-pipe and resonator spliced into the rear section of the TRD mid-pipe. The stock mid-pipe does not have the 2" "squeeze".
etherdude is offline   Reply With Quote
Old 06-23-2015, 12:07 PM   #9
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Most resonators will do that with time. It's from the heat and localized the hot spots that will warp the preforated core tube. Some cheaper ones I ran on my Rx7 would do that after a week. Magnaflow and cherrybomb glass packs will do that too.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following User Says Thank You to Hyper4mance2k For This Useful Post:
RobertPaulson (06-23-2015)
Old 06-23-2015, 01:59 PM   #10
celek
Resident Gear Head
celek's Avatar
Probably a Friday 5:00 manufacturing finishing time at the plant
Old 06-23-2015, 02:09 PM   #11
stevesnj
stevesnj's Avatar
Under warranty? Reminds me, gotta get that colonoscopy,...
My 2016 Build thread
The Following 5 Users Say Thank You to stevesnj For This Useful Post:
brandonblt2 (05-20-2016), flippy (06-23-2015), Hyper4mance2k (06-23-2015), RobertPaulson (06-23-2015), wparsons (06-23-2015)
Old 06-23-2015, 02:13 PM   #12
DAEMANO
Time Traveller
@Kostamojen replaced his resonator with a Vibrant 1141 2.5" Ultra Quiet Resonator in this thread.
Info and pics here:
http://www.ft86club.com/forums/showthread.php?p=2218064
The Following User Says Thank You to DAEMANO For This Useful Post:
drewbot (10-06-2015)
Old 06-23-2015, 02:16 PM   #13
Thorpedo
The SquadWhisperer
Info and pics here:
Yep, I'm doing the same (I think mine is a 1141, I'll have to look). I am also replacing the front section of the pipe with 2.5. The part after the resonator is 2.25 and that doesn't bother me as it is nicely made.
DAEMANO (06-23-2015)
Old 06-23-2015, 02:16 PM   #14
Thorpedo
The SquadWhisperer
Yep, but I'm using the opportunity to upgrade.
stevesnj (06-23-2015)
WARNING: Toms Taillight owners, check for melting! Kostamojen Cosmetic Modification (Interior/Exterior/Lighting) 214 04-23-2017 05:11 AM
WARNING: If you changed your transmission fluid, please read MrBodyMassage Engine, Exhaust, Transmission 47 05-09-2015 01:09 AM
Warning to Canadian owners about stock battery Suberman CANADA 46 03-02-2015 08:28 PM
The story that lead me to my FR-S! WARNING: Extremely long read ahead! Scubaru Scion FR-S / Toyota 86 GT86 General Forum 35 12-05-2014 01:47 PM
FT86 CLUB OWNERS - PLEASE READ HORSEPOWER DIRECT Announcements, Contests, Giveaways 3 01-03-2014 10:08 PM
