Old 06-22-2015, 12:50 AM   #1
2015FRShalo
Drives: 2015 Frs Halo 909 miles
Help finding right after market wheel hub adapter!
Hello fellow frs/brz/gt86 members!
My names Adam. I have a 2015. I swapped out the stock bucket seats for some aftermarket seats. The steering wheel is now sorta tight to get into. I want to find the perfect wheel hub adaptor that works with royal grips steering wheel and their quick release with there crest horn button. Could somebody help me find the correct parts to do this. Please and thank you it'll be highly appreciated.
2015FRShalo is offline   Reply With Quote
Old 06-22-2015, 01:25 AM   #2
swarb
The Following User Says Thank You to swarb For This Useful Post:
Jrryjms07 (06-22-2015)
Old 06-22-2015, 12:52 PM   #3
2015FRShalo
Originally Posted by swarb View Post
Wouldn't be on here if I didn't try searching. Was hoping to find someone willing to explain to me about it all and answer any questions I have I'm confused about it and don't have a clear understanding. I just don't want to order the wrong parts.
Old 06-22-2015, 01:51 PM   #4
swarb
connection to the to the car.
connection to the steering wheel, 6 bolt sparco type, 6bolt nardi, and 5bolt grant etc.
then you run into the problems of cheaper hub adapters that won't work on the horn, I know that works bell(the brand) works with the horn.
and then the problem of fixing the airbag light.
now search.
or just go to a shop or a online shop that specializes in parts for this car. its really not that hard.
Old 06-23-2015, 04:12 PM   #5
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Splash hub or Works Bell hub will work and they have a cut out for the clock spring. Make sure that you order an extra resistor as they are only shipped with one and this car needs two. One per harness connected to air bag and you should be fine.
The Following User Says Thank You to NyC Zn6 For This Useful Post:
adamg (06-23-2015)
Old 06-23-2015, 04:16 PM   #6
adamg
Drives: brz
Splash and works bell to my knowledge is the same thing. search for the DIY aftermarket wheel threads on here to get a lot of info and info on installation so you don't mess up your clock spring
but yes get the works bell hub and your good. any quick release will mount to it
adamg is offline   Reply With Quote
The Following User Says Thank You to adamg For This Useful Post:
NyC Zn6 (06-23-2015)
Old 06-23-2015, 04:40 PM   #7
NyC Zn6
NyC Zn6's Avatar
it's crazy because you actually helped me out when I was looking for the same information. Just used the information you told me ..thanks again bro
adamg (06-24-2015)
Old 06-23-2015, 09:44 PM   #8
2015FRShalo
Thanks I'll look into it right now! I actually found a found on how to install if anyone was wondering! [ame]http://youtu.be/-8IucJHAl3s[/ame]
Old 06-23-2015, 10:21 PM   #9
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
You had me until you said Grip Royal.
Then I threw up in my mouth a little
TylerLieberman is offline   Reply With Quote
Old 06-23-2015, 10:29 PM   #10
2015FRShalo
Lol any other steering wheels you would recommend? So far out of the ones I've looked at personally I like grip royal.
Old 06-23-2015, 11:38 PM   #11
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
I think he meant to say you said royal grip.
Old 06-24-2015, 08:33 AM   #12
NyC Zn6
NyC Zn6's Avatar
I got my Nardi Personal Grinta 330mm for only $280. I would look into Nardi, Sparco, or Keys Racing. There are plenty more just price them out.
2015FRShalo (06-24-2015)
Old 06-24-2015, 08:59 AM   #13
HyperTech
HyperTech's Avatar
Drives: Mazda3 2013 / Scion FR-S 2015
your talking like the search engine is perfect.
at least, show him how to use it properly if you know how, or show some result that might help him, instead of just putting a emoticon of a search button.
HyperTech is offline   Reply With Quote
Old 07-17-2015, 10:21 PM   #14
_gt86_user
Inactive
Drives: .
Did you ever end up installing the 540 hub on your 15'? That was one of the first mods I did and it did not line up straight with the spline like the OEM steering wheel, was off to the left or the right depending I even ended up selling the hub and ordering a Cusco suede wheel just to make sure and the Cusco wheel was off as well so I just went back to stock, after I tried on a friends 13' which went on perfectly straight, let me know if you got one on straight haha I still kinda want to install my Nardi.
_gt86_user is offline   Reply With Quote
BRZ NAV not finding satellites DSPographer Electronics | Audio | NAV | Infotainment 116 01-05-2020 08:42 PM
Need help finding Part # 914_WHITE_FRS Cosmetic Modification (Interior/Exterior/Lighting) 0 06-17-2014 07:41 PM
Help finding oem part # Jeong Scion FR-S / Toyota 86 GT86 General Forum 1 04-09-2014 12:06 AM
Help finding wheel finish similar to Pressed Graphite ericmpena Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 03-10-2014 10:38 PM
need help finding this Shipwreck Cosmetic Modification (Interior/Exterior/Lighting) 10 05-24-2013 12:06 AM
