Old 06-21-2015, 02:21 PM   #1
babydriver
Hit the road and I'm gone
babydriver's Avatar
Perrin Transmission Support report
I installed the Perrin transmission support replacement part yesterday on my FR-S:
It had the effect of immediately stiffening up the drive train. Previously, I had noticed a slight twisting of the transmission case (through the shifter of course) and a corresponding wiggle from the tail of the car. That is completely gone now. It launches very straight and the feel of the car is very solid and crisp when shifting. The part is inexpensive ($50) but it will take 1-2 hours to install and you will need to have access to a lift.
There is a noticeable increase in gear whine from the transmission in 1st-4th gears, due to the more solid connection between the tranny case and the transmission mount cross member but I did not find it annoying; in fact I rather liked it. Highly recommended if you don't mind the additional noise.
Slip, slidin' away.
Perrin Transmission Support & Whiteline Gearbox Positive Shift Kit jehu Suspension | Chassis | Brakes -- Sponsored by 949 Racing 66 12-14-2017 03:12 PM
Supertek Transmission Support Block - Now Available Supertek Industries Transmission and Driveline 14 05-24-2014 11:46 AM
Brand New - Perrin Shifter Bushing and Trans Support Philly758 Engine, Exhaust, Bolt-Ons 3 06-30-2013 03:09 PM
Perrin Master Cylinder Support TeamSweet86 DIY (Do-It-Yourself) Guides 0 12-09-2012 05:32 AM
