Old 06-20-2015, 04:04 AM   #1
_Taylorgaaaang
Drives: 15' WRB BRZ
Help with Racerx rear upper control arm install
Anyone here install these? Having trouble getting the ball joint on the stock ones out from the hub, anyone got some tips to possibly ease this part?
Thanks.
_Taylorgaaaang is offline   Reply With Quote
Old 06-20-2015, 05:03 AM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
I used a chisel as a wedge to spread the hole wider so the ball joint would come out. It took more force than I was expecting, but once done the control arm came out somewhat easy.
The Following 2 Users Say Thank You to Calum For This Useful Post:
Jeff@Racer X Fab (06-20-2015), _Taylorgaaaang (06-20-2015)
Old 06-20-2015, 02:14 PM   #3
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Ball joint seperater and a deadblow hammer. Hit the bejuses out of it. They are a pita. Also make sure your ebrake is off so the hub isnt locked in place
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
bhmax (12-30-2018), _Taylorgaaaang (06-20-2015)
Old 06-20-2015, 03:55 PM   #4
Jeff@Racer X Fab
Drives: Subaru BRZ, Toyota MR2 Turbo
Thanks.
Make sure you loosen the pitch bolt, sounds obvious but might have overlooked it. Never hurts to also spray a little WD-40 (or equivalent) as well.
Jeff@Racer X Fab is offline   Reply With Quote
The Following User Says Thank You to Jeff@Racer X Fab For This Useful Post:
Old 06-20-2015, 05:50 PM   #5
_Taylorgaaaang
Drives: 15' WRB BRZ
Thanks for the info guys!
Old 06-22-2015, 02:41 PM   #6
keonigt
Drives: 2022 BRZ
@_Taylorgaaaang hope it goes good bro!
keonigt is offline   Reply With Quote
RacerX Upper Control Arms Review DAMotorsports Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 05-27-2024 05:13 PM
Rear upper control arm ball joint? wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 01-06-2015 07:17 AM
WTB: Front Lower Control Arm and Rear Upper Control Arm YDNA Brakes, Suspension, Chassis 0 11-10-2013 04:40 AM
Adjustable rear upper control arms??? Supermassive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 09-29-2013 09:17 AM
Oem rear upper control arms Jhon19lopez Brakes, Suspension, Chassis 1 08-25-2013 09:01 PM
