Old 06-19-2015, 01:38 PM   #1
Simisimi
Drives: 2013 BRZ Limited w/ AVO Stage 1.5T
New WEDSSPORT TC105N 18x9.5 Wheels Installed
Finally made the move after much deliberation. These dropped over 2LBS per wheel vs. OEM while adding 1" diameter and 30mm wider tires.
I had Dunlop Direzza ZII 215/45/17 and replaced with Michelin Pilot Super Sport 245/35/18. This maintained nearly identical wheel size and avoided any need to adjust the speedometer, a plus. Also no rubbing problems whatsoever although clearance in the front to my new Eibach Pro lowering springs is as close as I would dare see.
So a reasonable 1" drop from the springs which provides a nicer look without serious compromise to clearance needed on New Hampshire frost heaved roads.
At the same time I also installed the Raceseng 3 piece Pulley Kit. It was shocking how much lighter these were than the OEM pulleys!
So I shaved like 6lbs off the pulley's and about 9lbs of unsprung tire/wheel weight. The heavier Eibach lowering springs added back a few lbs.
Aside from a new and (IMO) far better look, the car now has significantly better road stick in hard corners and at launch. Firmer suspension that is pleasantly not detectably harsher. And definitely I am noticing a real improvement in acceleration. Mind you I am already running AVO Turbo at 9PSI and a complete exhaust replacement. Last Dyno was 291 RWHP on a Mustang heartbreaker prior to these most recent upgrades.
Simisimi is offline   Reply With Quote
Old 06-19-2015, 03:04 PM   #2
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
very nice!
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 06-19-2015, 03:21 PM   #3
Timmy_Jones
Spun
Drives: 23' Supra
They look great.
Timmy_Jones is offline   Reply With Quote
Old 06-19-2015, 03:34 PM   #4
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
nice! 18x9 and 18x9.5's look so darn good on this car!
Old 06-21-2015, 10:07 AM   #5
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
We need more pictures bro
DuMa is offline   Reply With Quote
Old 06-21-2015, 11:28 AM   #6
BRZBYE
BRZBYE's Avatar
Drives: 2014 Subaru BRZ (Limited, Black)
Going to get my 18x9.5s installed to day. praying to god they clear the front springs. no coilovers, just Eibach Pro Kit
BRZBYE is offline   Reply With Quote
Old 06-22-2015, 10:17 AM   #7
Simisimi
Mistake on my original post. The wheels are WedsSport TC105N 18x18.5 +43mm. Tire size was correctly stated as 245/35/18. A tight but perfect fit. I honestly would not go wider. There's like 5mm clearance between the tire and springs in the front.
Did your 9.5" fit? What size and type tires did you go with? I am told there are slight differences between tire brand/model to consider too.
Old 06-22-2015, 10:21 AM   #8
Simisimi
Had one more pic handy.
Old 06-22-2015, 12:46 PM   #9
hamlet
Drives: blue brz, silver R8 5.2, orange s2K
These look good. You may want to recalculate your weights with the tires factored in though, as it will dramatically alter your unsprung weight expectations, especially with 18's.
hamlet is offline   Reply With Quote
Wheel Directory: WedsSport TC105N 18x9.5 +35 sidnacious Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 58 08-25-2016 12:23 PM
Wheel Directory: WedsSport TC105N 18x8.5 +43 / 18x9.5 +35 switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 02-29-2016 12:26 PM
TPMS sensor fit on aftermarket wheels, WedsSport TC105N in particular boomslang Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-04-2015 04:50 AM
WEDSSPORT TC105N 17x8.0/17x9.0 and 18x8.5/18x9.5 *** with Special. Ed Sticker *** RavSpec Wheels and Tires 47 06-22-2013 11:49 AM
LSD Motorsports WedsSport TC105N 18x8.5 +43 & 18x9.5 +35 Limited Edition Gunmetal LSD Motorsports Wheels and Tires 44 05-14-2013 11:47 PM
