Old 06-17-2015, 01:12 PM   #1
Pat
Pat's Avatar
Drives: 2023 BRZ
The dealer replaced my transmission and claims the driveshaft is worn out
The dealer recently replaced my transmission due to grinding during the 3 to 4 shift at redline. When I picked up the car with the new transmission there was a noise in the drivetrain related to load and speed. This noise was not present before the transmission was replaced. When I told the dealer about it they said the driveshaft now needs to be replaced. They claim the original transmission mated with the original driveshaft in such a way that they wore out together. Therefore, when the new transmission was installed, it didn't mate with the original driveshaft as it should. Because of this, I now need a new driveshaft, too.
Does this make sense to you guys? I've never heard of this happening, and wonder if the mechanic that did the work just wasn't careful and damaged my original driveshaft.
Thoughts?
Old 06-17-2015, 01:51 PM   #2
It's plausible, although not a certainty.
If it's under warranty, why not?
Old 06-17-2015, 02:00 PM   #3
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Assuming it's a warranty claim, let 'em do it. If the sound is still there, then it's BS, and the dealer has more work to do. If not, problem solved.
venturaII is offline   Reply With Quote
Old 06-17-2015, 02:04 PM   #4
Pat
Pat's Avatar
Drives: 2023 BRZ
I guess there's no harm, as it is under warranty. But I have very little confidence in the people doing the work. Therefore I want them touching the car as little as possible. It seems to me it is more likely the transmission replacement was not done properly and that is the real cause of this new noise.
Maybe the mechanic damaged the shaft when mating it with the tranny, or it just wasn't in all the way.
[insert "is it in yet?" joke here]
Old 06-17-2015, 02:09 PM   #5
gramicci101
Off Topic
I agree with your theory of them damaging it. Driveshafts and transmissions are interchangeable; they don't come as a matched set. And if the u-joints on the driveshaft were wearing out, you'd have heard it with the old transmission too. They didn't magically develop increased wear to the point of making noise just because the driveshaft was removed and reinstalled.
Old 06-17-2015, 03:34 PM   #6
OkieSnuffBox
Drives: '23 BRZ Limited
Is it a sound or a vibration?
I haven't looked under these cars yet, are they a 2-piece driveshaft with a Center Support Bearing? Perhaps he just pulled the front half to do the trans and installed the front half clocked wrong and now it's out of balance.
*From the old BMW days*
Old 06-17-2015, 03:47 PM   #7
markw
Drives: 2014 FR-S
Is it at engine speed, or road speed? Ie, if you throw the car in neutral does it go away? Or if you have it in neutral and rev the engine does the sound change?
markw is offline   Reply With Quote
Old 06-17-2015, 03:52 PM   #8
Pat
Pat's Avatar
Drives: 2023 BRZ
I only hear it in first gear soon after the clutch is released. At dealer now waiting for them to pull the car around.
I believe it is a sound caused by a vibration.
Old 06-17-2015, 04:35 PM   #9
stevesnj
stevesnj's Avatar
If the dealers theory about wearing out together then why didn't he replace the driveshaft also? Id tell him to put in a new driveshaft if it's under warranty, if not they may have just installed the driveshaft out of phase if it's a slip joint driveshaft or the u-joints are bad or even possibly it just needs to be balanced.
My 2016 Build thread
Old 06-17-2015, 05:12 PM   #10
Pat
Pat's Avatar
Drives: 2023 BRZ
They put in a new driveshaft, looked at it multiple times and the noise is still there. Going to have another dealer look at it tomorrow.
Old 06-17-2015, 05:14 PM   #11
gramicci101
Off Topic
Then maybe the noise is being caused by the new transmission. Maybe they installed it wrong (shift linkage goes up!) or maybe it had issues before they put it in.
Old 06-17-2015, 05:29 PM   #12
wheelhaus
wheelhaus's Avatar
New shaft, and the plot thickens, geez.
You did a great job clearing up the drama and just stating the raw facts, Pat. Nice job! lol
I was under the impression these transmissions were simply replaced with new units, it takes more time and expense to pay a tech to rebuild it and replace individual parts. If this is untrue, then please let me know.
This also makes me wonder, if instead of receiving new transmissions, if we're actually getting transmissions rebuilt at some factory service center. They get pulled apart, inspected, "repaired", and rebuilt. Just my own personal suspicion, but it would explain why a "new" tranny is noisy. Unless a bearing or something was somehow damaged during install.
If the sound comes from/after clutch action, could it possibly be clutch related?
There is a center support bearing, its not just one long shaft. However, I don't believe there's a way to separate the center portion, or at least not easily. I'm not 100% certain on this, but I have read threads before where shaft clocking was questioned and subsequently quelled.
wheelhaus is offline   Reply With Quote
Old 06-17-2015, 05:32 PM   #13
gramicci101
Off Topic
I would put money on this being the case. It's more cost effective for the manufacturer.
Old 06-17-2015, 06:02 PM   #14
Pat
Pat's Avatar
Drives: 2023 BRZ
I was told the tranny was new. I have no reason to believe otherwise, but who knows?
It could be clutch related, but the feel makes me think it is driveshaft related. I'm no pro, so I could very well be wrong.
It seems to me as if the driveshaft rotating at a certain speed is what causes the issue. Perhaps it is not balanced properly. That seems like the simplest explanation.
Replaced transmission fluid, now it's causing problem frslee Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 37 11-02-2016 05:35 PM
6th Gear Grind & Replaced Transmission Bonburner Issues | Warranty | Recalls / TSB 45 07-30-2016 11:08 PM
Which dealer to go for transmission warranty ironsurfer129 Southern California 17 02-21-2015 03:16 PM
6 MT Swap, Complete: Transmission,Starter, Flywheel, Clutch, Driveshaft, Pedals, Hydr ecda Transmission and Driveline 2 01-30-2014 10:45 PM
