Drives: '13 Asphalt FR-S
Racingbees.com foglight kit (oem style kit)
So I finally got the kit from racingbees.com from Canada for $145 shipped. I got it within a week(maybe less).
This is the kit in question: http://racingbees.com/index.php?rout...roduct_id=1073 Basically, it's the copy of the OEM kit. The fogs themselves are Winjet branded, the wiring i assume is their own. Wiring is the exact same as the OEM kit as well, so it comes with ground wire, plug to fog, and then pin that goes into turn signal. Also comes with the actual bezel in the cabin for the extra fog button. AND YES THE FOG INDICATOR LIGHTS UP IN THE DASH! This was the cheapest kit i found online that had this function. Pros: -oem style -non-glossy fog bezel -INDICATOR LIGHTS UP! Cons: (very minor) -the actual button for the fogs has a light indicator on it, and that lit up for a second then burnt out after. however the actual icon on the button is translucent so it'll still light up, just not the indicator above it. -fog bezel seems a little loose, wish it was a tighter fit, but it's not going anywhere -there's a gap between the actual fog bezel and the fog light itself, but seems like it's supposed to be that way even with the OEM kit. Conclusion: I'm very very happy with this kit, and I'm glad I finally found one that is basically like the OEM kit but 200 dollars cheaper! Like I said before, I really wanted it to work like OEM and have the light indicator work in the dash and I finally got it. Install took about an hour for me. Thanks RacingBees! |
look really nice, you should change to white bulbs or yellow bulbs.
| racingbees.com foglight kit-anyone tried? | Fang | Cosmetic Modification (Interior/Exterior/Lighting) | 16 | 06-24-2015 06:43 PM |
| FS: Rear foglight kit, kit #3, F1 style. | tigermack | Exterior Parts (Aero, Lighting, Etc.) | 1 | 12-22-2014 10:58 PM |
| BRZ/FRS VIS Carbon Fiber oem style hood and AMS style trunk. BNIB. | js0uth | Exterior Parts (Aero, Lighting, Etc.) | 76 | 12-03-2014 04:37 PM |
| All Aero Kits Sale! ML, TRD Style, RB style and more. | ShowstoppersUSA | Exterior Parts - The Rest | 27 | 02-28-2014 06:56 PM |
| Seibon FA Style Hood and CSL Style Trunk | invisage | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 04-17-2013 01:39 AM |
