Old 06-12-2015, 07:08 PM   #1
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
ASM Autobacs / TODA throttle body
google translate is not good enough.. can anyone translate please?
http://www.autobacs-asm.com/blog/asm...s_view&no=2865
mokinbird87 is offline   Reply With Quote
Old 06-12-2015, 08:13 PM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
Looks like a bored out OEM unit.
Old 06-12-2015, 09:34 PM   #3
mokinbird87
BOXER FR
is this your speculation or does it say that anywhere?
Old 06-12-2015, 09:44 PM   #4
Calum
That Guy
Pure speculation. Sorry to disappoint.
Old 06-13-2015, 04:19 PM   #5
Epic_integra
Drives: Brz
hey this throttle body is only 2.3 mm bigger not worth it
Epic_integra is offline   Reply With Quote
Old 09-10-2016, 05:33 AM   #6
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
This is one of the most basic modifications in ASM Autobacs, but not well known in Western countries. Even a 2.3mm increase in the valve diameter, it makes a considerable change in the circle area. Standard valve diameter opening is 65mm and with the change it goes to 67.3mm. Circle area is 3316 and after change it goes to 3555. Overall a 7% increase.
Additionally, they create a tapered entrance in the throttle body with a maximum diameter opening of 72mm:
This helps to accelerate air flow even more using the Venturi effect.
Old 09-10-2016, 09:25 AM   #7
Lantana frs
Drives: 13 frs red
I think Subaru has a pretty good idea what the venturi size should be.
Lantana frs is offline   Reply With Quote
WTB FRS/BRZ Throttle Body Tboxer Want-To-Buy Requests 3 12-01-2014 12:13 PM
Heated throttle body? Turdinator Engine, Exhaust, Transmission 19 04-06-2014 11:21 AM
Toda Racing Big Single Throttle ANREX Engine, Exhaust, Transmission 27 06-14-2013 01:14 AM
