Drives: 2015 Scion FR-S
Tranny Rattle ???
Has there been any agreement among FRS/BRZ owners as to the cause of the well reported "transmission rattle" when slowing down in neutral? I've seen all kinds of theories suggested here - engine valve noise, fuel pump noise, exhaust noise, piston slap, etc. I think its in the transmission/clutch because when the clutch is pushed in the noise stops immediately. It only happens for about 2-3 seconds at about 700 rpm, clutch out in neutral. What is the best educated guess to what makes the noise???
ArtS - 2015 FR/S manual tranny |
#2 | |
You can alleviate the issue with tuning to bump idle to 750 and switch to full direct injection mode at low loads, instead of combination pi\di, this allows ecu to manage idle stability better. |
Steve99 - Thanks for the reply but I don't think I agree. When the condition I describe occurs I am in neutral coasting to a stop. The cars momentum is not turning the engine. Only when I am almost stopped and the RPM is down to 650 -750 do I hear clearly the noise from the clutch/tranny area. Your 2nd sentence about "bumping the idle and switching to full di", wow, I'm not in that league. Thanks anyhow.
Art |
#4 | |
search for idle stability issues |
Steve99 - Thanks for the second reply. I think I like this answer a little more than the first one. By the way, isn't the internet amazing? I sit here in South Carolina, ask a question on my computer and in a couple of minutes I get a reply from Australia. God, what a world we live in!
Art |
#6 | |
ZA1JB01C or if latest model car ZA1JD00C You can do that with android torque application and cheap elm327 adapter if it not one of those dealer should update you to latest one for your car. If you had a flash device I could send you a new tune :-) |
Drives: 2013 Satin White Pearl BRZ
There is a tsb for rattling shifter, it has to do with bushings and they replace the whole shifter. Maybe this will help
Sent from my SAMSUNG-SM-G900A using Tapatalk |
#8 | |
![]() (jest ah messen wich ya ..... )humfrz |
humfrz -
No matter what you say the internet is one of the most significant developments of the last century. I am old enough to have been around before you were born, the internet was created, before cell phones and even before tv! Its all a matter of historical perspective. So, I know you were just kidding around, but I'll stick with my comments and say "wow, what a world!" ArtS |
| Cheap Tranny?? | C130NAV | NY / NJ / CT / PA | 8 | 11-05-2014 02:23 PM |
| FRS Tranny | C130NAV | Want-To-Buy Requests | 4 | 10-30-2014 10:01 AM |
| How do I check the tranny oil? | mashal | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 08-18-2014 03:03 PM |
| Confirm Tranny Oil | Mac1235 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 12-31-2012 02:37 PM |
| MT vs AT tranny... better MPG, 0-60? | subatoy | BRZ First-Gen (2012+) — General Topics | 163 | 03-26-2012 06:08 PM |
