Drives: 2014 Toyota GT86
Supercharger with lightweight crank pulley....is it safe?
yes! As the title stated is it safe to install light weight crank pulley with HKS Super charger?
No Money, No Problems
![]() (I'm pretty sure it's fine) |
Senior Misanthrope
LWCP is always a contentious topic around these parts. Aside from the usual arguments (omg harmonic damping!) I can't think of a reason why a SC would make things worse.
Drives: 2015 Series.Blue
More power = worse harmonics
(this is why SFI rated dampers are usually bigger and heavier for engines running lots of boost) |
I've run with and without lwcp and chose to stay without. There really are no gains to be had, and it makes the car harder to drive on a daily basis.
To answer the op, don't bother.
Thank you for your inputs. I would put back the original LWCP just to be safe and worry free.
Bilge monkey
Drives: '13 BRZ, 82 starlet
after lurking for many years on many forums, i avoid lightweight aluminum pulleys. so many fails from almost every manufacturer.
Sarcastic SOB
I have the exact setup shown in the pictire. Seems to run perfectly fine and no difference in drivability.
| Supercharger + Lightweight Crank Pulley? | Efferalgan | Forced Induction | 5 | 09-29-2014 11:23 AM |
| Lightweight crank pulley | Vlady | Engine, Exhaust, Transmission | 112 | 01-09-2014 09:28 PM |
| Lightweight Crank Pulley | Vlady | Want-To-Buy Requests | 3 | 01-02-2014 11:31 AM |
| FS: AgencyPower Lightweight Crank Pulley | Firestorm_86 | Engine, Exhaust, Bolt-Ons | 0 | 11-22-2013 04:13 PM |
| Ralco RZ Lightweight Crank Pulley HELP! | JERZgrl88 | Engine, Exhaust, Transmission | 11 | 10-10-2012 12:41 PM |
