View Poll Results: Honda NSX
Sub-Zero 41 80.39%
Cool 7 13.73%
Uncool 2 3.92%
Seriously Uncool 1 1.96%
Voters: 51. You may not vote on this poll
Old 02-14-2012, 02:26 PM   #1
M-17
Ninja Cat Mod
M-17's Avatar
94 Acura NSX Type-S (NA1) - SUPER STREET MAGAZINE
1994 Honda NSX Type-S (NA1) - Hol-E Shhhhh...
Esprit’s Take on the Honda NSX Will Have You Reaching For the Heavens In No Time.
By Dino Dalle Carbonare
Time attack is a curious game. On paper it is one of the least exciting forms of motorsport; after all, watching cars go around a track for short stints to improve upon their own times isn’t exactly groundbreaking entertainment. But, despite this, the way it continues to grow, there’s obviously an interest there that keeps it going, and that’s really the cars themselves. In Japan, time attack has always been about the tuning; enthusiasts follow their favorite demo cars religiously, and in most cases, it’s a chance for most shops to push the envelope of engine and chassis tuning. To go balls-out extreme, if you will, an Esprit’s NSX is a perfect example of balls-out “crazy”. A car that once started as a bone-stock Type-S is now a lot closer to resembling the type of racer that takes home Super GT championships.
Sitting in a very quiet and dark pit garage at Suzuka Circuit, the Esprit NSX oozes the kind of personality that million dollar racecars usually have. Every detail has been fine tuned for the ultimate performance, from the angular and sculpted widebody to its highly-modified engine. All the work was done in house at Esprit’s workshop, less than a five-minute drive from the word famous track, and it’s painfully obvious no cost has been spared to guarantee the ultimate in quality and performance.
Take the aero package, for example: everything has been shaped to keep the car planted to the ground; massive carbon-fiber front and rear diffusers and a tall rear wing help out tremendously with downforce. The widened fenders increase the track of the car so it can handle more speed through the corners while air flows over and around it in a more efficient and less turbulent way. Carbon-fiber not only reduces weight but it’s strong, and that’s why they used a vented piece instead of a heavy factory metal hood, plus it helps move air out from the radiator, as well as the doors and engine cover. Even the trunk lid is made from carbon material and through its massive air scoop, forces air down into the rear-mounted intercooler.
With the goal to create the fastest NSX in Japan, and possibly the world, Esprit did what needed to be done; the resulting costs a mere necessity. With inspiration from Super GT NSX racecars, Esprit knew that in order to achieve the ultimate weight balance, you must change the engine’s layout so that it runs longitudinally. Doing this also allows you to use a Hewland sequential transmission, a must-have when it comes to racing. One might say that changing a car’s drivetrain configuration is excessive, but when it comes to competition, Esprit takes things very seriously. They tore the entire rear end apart and custom fabricated engine mounts to a steel rear subframe that would house the new engine configuration, transmission and the suspension. A used Hewland sequential was sourced and fitted onto the now 90° rotated CA30 by means of a custom-made bellhousing. As the V6 now sits “straight” in the chassis, a whole new twin-turbo system could be designed, an upgraded version of what the previous version of the demo car was running. A pair of Trust T517S turbos are used and mounted on custom manifolds, positioning them low on each side of the engine. To handle the extra boost and extreme racing, the alloy V6 was taken apart and the bottom end fortified with a balanced C32 crankshaft, Esprit’s own connecting rods and forged pistons. Esprit also ported and polished the cylinder head and developed their own cam grinds as well. The team tuned the engine with a HKS F-Con VPro ECU, and we’re proud to say, there’s 690 horses being produced, over double what the engine puts out in stock form.
When it came time to set up the suspension, who better to call for a little custom work than HKS? They delivered in fine form with specially made Hiper Max Pro coilovers that are setup to handle both Suzuka and Fuji Speedway. Braking now consists of 6-pot Endless front calipers and Brembo 4-pot rears with all sides mated to 355mm discs and Endless pads. And if you’re craving even more custom work, look no further than the interior. Pop the carbon doors open and peep the carbon firewall, which helps shield the driver from the heat and noise the V6 generates. A 12-point cage keeps the car’s driver, Tarzan Yamada safe as he’s positioned in the Bride bucket. A rear bumper cam is linked to a LCD screen since the rear engine cover blocks the rear view. On one of its first times out on a track, at HKS’ Premium Day, Tarzan posted a 1:43.594 lap time and securing a win in the 2WD Class of Option Max’s time attack.
After years of experimenting with naturally aspirated NSXs, it seems Esprit has the knack to not only make those setups winners, but also those that are force-fed. With this project, they’re ready to break records. Where exactly it will happen is anyone’s guess. We’ll just have to wait and see what Esprit delivers us, and it better be the goods.
Tuning Menu
Owner Esprit
Hometown Suzuka, japan
Occupation Sick car builder
Power 690hp, 495lb-ft
Engine C30A engine, custom fitted in longitudinal position; Esprit custom engine mounts, forged pistons, connecting rods, balanced C32 crankshaft, ported/polished cylinder heads, cams, stainless steel manifolds, stainless exhaust, intake pipes, intercooler piping with custom twin-entry end tanks, intake plenum, dry sump, oil pan, oil tank, radiator and air separator system; Trust/GReddy T517Z turbos (x2), intercooler and oil cooler; HKS SPF air filters and fuel pump; Nissan Q45 throttle bodies
Drivetrain OS Giken twin-plate clutch and limited-slip differential; Esprit custom bell housing; Hewland 6-speed sequential transaxle transmission
Engine Management HKS F-Con VPro ECU
Footwork & Chassis HKS Hiper Max Pro adjustable suspension; Esprit custom rear subframe
Brakes Endless 6-pot front calipers; Brembo F40 4-pot rear calipers; Endless 355mm brake discs and brake pads
Wheels & Tires 18x9.5" Prodrive GC-010G wheels; 265/35R18 Bridgestone Potenza RE11S tiresexterior
Exterior Esprit full widebody kit, including front bumper, carbon-fiber front diffuser under cover, dummy headlights, hood, wide front fenders, doors, GT side skirts, wide rear fenders, rear bumper, engine cover, trunk lid with intercooler intake, adjustable GT wing and rear diffuser; Craft Square carbon-fiber side mirrors
Interior fully spot-welded chassis; custom rollcage and engine bay reinforced structure; custom carbon-fiber firewall; Bride Low Max bucket seats; HPI racing harness; MOMO steering wheel; custom extended steering boss; Stack dash unit; HKS boost gauge and EVC Black Limited boost controller; Lapshot P-LAPII lap timer; Auto Meter fuel gauge; carbon-fiber center console with rear-view LCD monitor; custom Esprit shift lever and linkage
www esprit.to; greddy.com; motovicity.com (HKS)
Old 02-14-2012, 04:20 PM   #2
serialk11r
Drives: '06 AM V8V Coupe
Shit...
Old 10-30-2013, 02:01 AM   #3
Joakim3
Joakim3's Avatar
Drives: 04' Saab 9-5 Aero
FT86CLUB Cool Wall: Honda NSX
Honda NSX
The Specs
Production: 1990-2005
Style: 2-Door Coupe
Engine: V6 (270 hp / 210 lb-ft to 290 hp / 224 lb-ft)
Transmission: 5- / 6-speed Manual or 4-speed Automatic
Layout: RMR
_____________________
You know what they say... pick two: cheap, fast, reliable.
Joakim3 is offline   Reply With Quote
Old 10-30-2013, 02:42 AM   #4
zygrene
zygrene's Avatar
Drives: 1991 Formula Red NSX
My favorite car of all time. Sub-zero without a doubt.
zygrene is offline   Reply With Quote
Old 10-30-2013, 07:08 AM   #5
Burrcold
Drives: Subaru BRZ Limited
A super car for the common man (well sort if).
Sub zero IMO.
Old 10-30-2013, 09:11 AM   #6
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
The girl would look at the Acura badge and say Really, honey?
Uncool.
Old 10-30-2013, 11:32 AM   #7
Joakim3
Joakim3's Avatar
Uncool.
It's an old school acura, which are badass...... The orginal NSX is a better bang for the back than any girl in the first place so it overrides "that" rule (and it WOULD get you laid regardless), ... Oh and it's an NSX
Sub f*ing zero
Old 10-30-2013, 01:42 PM   #8
strat61caster
strat61caster's Avatar
Uncool.
TIL girls have judgements on Acura. Enlighten me.
ineedyourdiddly
Old 10-30-2013, 02:03 PM   #9
Noble713
Noble713's Avatar
Drives: MkIV Supra & Evo X
Didn't Chris Harris say he preferred it over the Pagani Huayra in that video where he drove both on the same roads?
Probably the only Honda I'd ever own. Definitely Sub-Zero.
1994 Toyota MkIV Supra (project car)
2007 JDM Mitsubishi Exo X GSR-SST (Daily driver)
Noble713 is offline   Reply With Quote
Old 10-30-2013, 02:26 PM   #10
DarkSunrise
DarkSunrise's Avatar
Voted sub-zero. I love how that picture shows how expansive the view out the front is. That's one of the under-appreciated things about putting the engine in the middle/rear and building a car before modern-day crash standards.
2022 BRZ Build
2013 FR-S Build
Old 10-30-2013, 04:26 PM   #11
OrbitalEllipses
Drives: Attitude
Uncool.
First mass production V6 using titanium bits. Seriously sub-zero cool, go home troll.
Old 10-30-2013, 04:28 PM   #12
B L U E S L A T E
Drives: BMW E84
Without a doubt. Been in my top 3 "Got to own" list for past.... 2 decades. lol
B L U E S L A T E is offline   Reply With Quote
Old 10-30-2013, 05:24 PM   #13
Joakim3
Joakim3's Avatar
When I saw the pic, I just knew it would did the car that much more justice
Old 10-30-2013, 05:33 PM   #14
ronboogieon
BReeZy Hunter
ronboogieon's Avatar
Drives: 13 DGM BRZ Limited 6MT
The only Honda that I crave for. Timeless classic.
ronboogieon is offline   Reply With Quote
Acura Type-S Concept / Introducing The All-New 2021 Acura TLX - Type S Jordanwolf Other Vehicles & General Automotive Discussions 135 06-23-2021 09:45 AM
FS: 2005 Acura RSX Type-S AznKirby Canada Classifieds 12 06-05-2015 10:21 PM
1991 Acura Nsx Bach415 Cars for Sale/Trade 13 02-20-2014 09:29 PM
2005 Acura TL automatic, leather, loaded, clean, original owner jjdrivesajazz Northern California 0 05-15-2013 04:07 PM
Supercharged 2005 Acura Rsx type s Jerminator Cars for Sale/Trade 3 02-05-2013 09:46 AM
