Old 06-03-2015, 10:40 PM   #1
Sugi
Sugi's Avatar
Drives: 2015 FR-S - Halo
OEM Toe Arms Adjustable?
Are the OEM toe arms on the FRS adjustable? I'm getting an alignment done tomorrow and need to know if they can be adjusted
Sugi is offline   Reply With Quote
Old 06-03-2015, 11:07 PM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
Yes
Old 06-04-2015, 01:36 AM   #3
Sugi
Sugi's Avatar
Originally Posted by cjd View Post
Yes
Thank you. I don't suppose you know the amount of degrees it can be adjusted?
Old 06-04-2015, 01:53 AM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
A shit ton. Enough that the question sounds kind of weird. What exactly is your concern?
Old 06-04-2015, 04:17 AM   #5
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Si
Old 06-04-2015, 12:57 PM   #6
Sugi
Sugi's Avatar
Well... I ordered SPC lower arms and they came with toe adjustments. Just wondering if I should install the SPC toe adjustments or if the OEM ones will be suffice?
Old 06-04-2015, 01:00 PM   #7
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
SPC comes with offset toe bushings that require the stock ones to be pressed out. They are meant to provide additional adjustment for lowered cars, however this depends on what ride height you want the car to be at.
Considering you don't know what ride height you want your car to be at (see replies in your other thread in this subforum), you should first figure out what ride height you want the car to be at and whether or not there is sufficient toe adjustment to meet your needs.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
Ultramaroon (06-04-2015)
Old 06-04-2015, 01:14 PM   #8
wparsons
wparsons's Avatar
Amount of toe correction isn't directly related to ride height, it's related to how much you're changing the camber via the LCA. The more you
That said, if the car is lowered a lot and you're dialing out a lot of camber, you'll probably run out of toe adjustment range.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Old 06-04-2015, 01:20 PM   #9
Ultramaroon
not playing cards
I love this forum and the learning process.
Old 06-04-2015, 01:40 PM   #10
mav1178
mav1178's Avatar
Yeah, I was mostly trying to point out OP's fallacy in logic on how to get alignment settled for his car.
Figure out what ride height first, then figure out the rest.
-alex
wparsons (06-04-2015)
Old 06-04-2015, 07:39 PM   #11
Sugi
Sugi's Avatar
So... got the alignment today and the tech stated that he has never seen toe off by that much before. I'm lowered about 2" on Tein Street Flex w/ SPC lower control arms. The tech stated that the OEM toe arms are really good and he was able to put everything in the green with room to spare so the toe bushings from SPC weren't needed. Hope this helps someone in the future.
The Following 2 Users Say Thank You to Sugi For This Useful Post:
Baldoak (06-05-2015), Plumbus (12-10-2020)
Old 06-04-2015, 08:01 PM   #12
wparsons
wparsons's Avatar
How much did you adjust the camber? That's what affects toe, not ride height.
flickr
DIY: Whiteline Rear Adjustable Toe Arms RallySport Direct DIY (Do-It-Yourself) Guides 1 07-10-2015 09:38 PM
Adjustable control arms and Toe arms zumin Brakes, Suspension, Chassis 12 07-08-2015 06:54 AM
WTB: Adjustable Toe Arms srizzors25 Want-To-Buy Requests 0 03-26-2015 01:12 PM
SPC Adjustable Toe Arms Johnny_MA Brakes, Suspension, Chassis 1 07-29-2014 12:55 PM
SPL Adjustable Suspension Arms?? Trmx2 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 11-28-2013 01:22 AM
