Old 06-01-2015, 02:46 AM   #1
dgerny
Drives: 2013 Scion FRS
E85 help!! Pls
So I have oft and I want to get a flex fuel kit. I know about all the brands but what I am trying to get is, what do I need to do to use a flex fuel kit with a off tune? What tune do I use or do I just plug it all in and just let it do whatever it wants. Please help me understand
dgerny is offline   Reply With Quote
Old 06-01-2015, 03:34 AM   #2
diodelphi
diodelphi's Avatar
Drives: 86
OFT guys specially Steve could help you
diodelphi is offline   Reply With Quote
Old 06-01-2015, 04:19 AM   #3
steve99
The openflash tunes supplied are either ,Petrol OR E85.
you either run a dedicated petrol tune petrol with petrol
or you run a dedicated E85 tune with E85
if you want to switch then you have to run your tank down to the low fuel light fill with other fuel and then flash the appropiate E85 or petrol tune.
see links below for more info
The oft tunes do not support flex fuel system.
A flex fuel syetem requires a ethanol sensor which measures the ethanol content and this is converted into a voltage , this voltage is fed back to an input on the ecu and the ecu interprets this voltage and adjust the tune according to the ethanol content.
However to interpret the ethanol sensor input requires aditional software code to be written for the ecu.
This has not been done for oft tunes.
If you want a flex fuel system you will have to buy ecutek system
and a flex fuel kit.
about $700 for kit plus ecutek licience 300. plus flex fuel tune
diodelphi (06-01-2015)
Old 06-01-2015, 09:49 AM   #4
Koa
"do I plug it all in and let it do what it wants"
loool don't touch your car bro.
