Old 05-31-2015, 12:01 AM   #1
ZachTTerrell
Drives: Black 2013 Scion FR-S
Lets dumb this down for me.. Rim size
Hey guys. So I've posted once before and decided to give this a try although I might get some negative feedback because the info is probably already out there. Anyways, I have a FR-S on the stock 17" rims at stock height and stock everything else. I want 18" rims and also want to go a little wider. Maybe 18X8.5? Anyways, I don't want to have to change ANYTHING about raising or lowering or fenders. All I want are 18" rims that are the same width all the way around. How wide can I go without changing anything else? There's a lot of stuff out there on the forums but I just don't understand all of the measurements in the wheel and tire forums.
Thanks,
Zach
ZachTTerrell is offline   Reply With Quote
Old 05-31-2015, 12:06 AM   #2
swarb
If you don't understand. Search and learn it. It's really not that hard.
If it is too hard, just go into a wheel shop or tirerack.com and they will pick the right sizes for you.
Also look in the sticky topics on the top of http://www.ft86club.com/forums/forumdisplay.php?f=24
There are three basic measurements.
1. diameter = you have that figured out.
2. width = not too difficult
3. offset (or backspacing) = learn it, or have a shop figure it out.
Or just copy someone else's setup.
Old 05-31-2015, 12:12 AM   #3
Bergen23
Drives: '15 Halo FR-S
18x8 or 8.5 +35. 225/40 or 235/40 rubber and you're good to go.
Bergen23 is offline   Reply With Quote
Old 05-31-2015, 12:16 AM   #4
ZachTTerrell
With that I would be fine with everything else stock?
Old 05-31-2015, 12:17 AM   #5
ZachTTerrell
Yeah I'm still working on it. Definitely a learning process haha
Old 05-31-2015, 12:19 AM   #6
Bergen23
Yup
Old 05-31-2015, 12:24 AM   #7
jimmillion
Power Ranger Elite
jimmillion's Avatar
Drives: '13 WRB Sport-tech
To add to what Bergen said above.
Anything that's between 18" x (7.5" to 8.5")width + (35-50)offset...
...and you'll be good sticking with stock everything else.
A heads up, the offset is how "flush" it'll be. So the closer it is to +35 then the flusher it'll be.
For tires.. Just go with whatever size the shop tell you after you pick out the rims you want. They won't steer you wrong.
Good luck. And post picks after in the "what did you do today thread"
jimmillion is offline   Reply With Quote
Old 05-31-2015, 12:24 AM   #8
ZachTTerrell
Thanks
Old 06-10-2015, 02:05 AM   #9
ZachTTerrell
Thank you for your advice! I followed it and got Enkie Raijin's 18x8.5 +45 all the way around and the look freaking awesome
The Following User Says Thank You to ZachTTerrell For This Useful Post:
jimmillion (06-11-2015)
PSA I'm a dumb ass ogrowup Scion FR-S / Toyota 86 GT86 General Forum 5 12-24-2014 01:32 PM
Maybe I'm just dumb or something... BRZlimited Issues | Warranty | Recalls / TSB 8 03-04-2014 03:59 PM
anyone else dumb enough? 5th 86 CANADA 8 04-18-2013 04:30 PM
Dumb me... feldy Engine, Exhaust, Transmission 3 07-26-2012 10:46 PM
