Old 05-27-2015, 11:29 AM   #1
Frs30
Drives: 2013 Fr-s Hot Lava
Will a stock BRZ headunit with Navigation fit in an FRS?
I've been looking through thr threads and can't seem to get an answer. I have a chance to buy a stock 2013 BRZ head unit with navigation for a good price, and wanted to know if its possible if it will connect into a 2013 FRS (as far as the connectors go). I don;t want to buy this and then not be able to connect it to my FRS. any info would be appreciated. My FRS is a base model 2013. 6 speed. Thanks
Frs30 is offline   Reply With Quote
Old 05-27-2015, 12:25 PM   #2
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
Unless youre getting it for 50 bucks save your money and get a better headunit. The stock one is garbage
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
Old 05-27-2015, 02:13 PM   #3
fika84
fika84's Avatar
http://www.ft86club.com/forums/showthread.php?t=25324
http://www.ft86club.com/forums/showthread.php?t=65867
Those are a couple worth reading through.. moral of the story seems to be it's not worth it. Just buy an aftermarket head unit, get better quality and it can be plug n play.
fika84 is offline   Reply With Quote
Old 05-27-2015, 08:03 PM   #4
brzsubarusti13
Drives: 2013 Subaru BRZ
Ive been thinking about selling my headunit. I also have the whole antenna setup that will be required for it to work. Let me know if you are going to go though with it.
brzsubarusti13 is offline   Reply With Quote
Old 05-28-2015, 05:27 AM   #5
P3tras
Drives: Subaru BRZ '13 WRB
It is basically plug and play. However, you will need GPS from BRZ as well (it sits besides head unit). Satellite radio will not work, unless you get BRZ antenna and route wires (PITA). Other than that, it should be plug and play. As I know only antenna amplifier is on different connector, thus you would need to swap 1 lead.
P3tras is offline   Reply With Quote
Old 05-28-2015, 12:13 PM   #6
BobbyDee
BobbyDee's Avatar
Drives: 2013 FRS 6MT
This is true. If your not getting a hell of a deal you should spend a couple more dollars on a better unit. My friend with the same radio on his BRZ talks how great my scion 2014+ OEM Bespoke /w Navi is. Honestly used both radios and my radio is a lot more responsive than his. Good luck tho! Wanna see the outcome
BobbyDee is offline   Reply With Quote
Old 05-29-2015, 11:42 AM   #7
theanswer3
theanswer3's Avatar
Drives: White BRZ Limited
It is 100% plug and play. It uses the same exact toyota harnessess as the FRS. As long as the gps antenna is provided, the unit will work pefectly fine and take all of 15mins to install. I have a BRZ and installed a pioneer unit before I went aftermarket and I just took out old radio and plugged in new radio, there was nothing else needed.
2013 Subaru BRZ Limited Pearl White
DRL mod/3D MAXpider custom floor mats/TRD red stitched armrest V2/K&N Air Filter/Superbright LEDs everywhere/Pioneer 5000NEX DD Screen/kicker 600.1/tinted windows/TenzoRacing Cuzco v.1 18x9/Valenti black tails and reverse light
theanswer3 is offline   Reply With Quote
brz, frs, head unit, navigation, wiring
brz navigation headunit in frs? p00mba Electronics | Audio | NAV | Infotainment 9 02-20-2015 02:51 PM
FS - Toyota GTS navigation divx stock headunit Speedoponic Australia Classifieds 1 08-29-2014 11:32 AM
2014 Bespoke Head-unit with Navigation and AHA Bundle- Headunit plus accessories DC2R Audio/Visual, Electronics, Infotainment, NAV 6 06-11-2014 06:58 PM
Navigation System without replacing headunit Mikeez Electronics | Audio | NAV | Infotainment 0 04-17-2014 05:15 PM
2014 pioneer headunit with navigation and aha Red FRS Audio/Visual, Electronics, Infotainment, NAV 11 11-18-2013 01:16 PM
