Old 05-20-2015, 08:10 AM   #1
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Question Turbo rust(center section)
Has anyone had their turbo, center section in my case, rust. I've searched around but it seems not to be too common, then again this isn't an oem turbo car so not many chances of everyone having the same outcome. My turbine housing is coated so that wont really rust, but I'm getting rust all over my center section and I know that's not good. It looks so ugly im embarrassed to even snap a pic. Im certain this has to do with the vented hood install as I probably have 100% more humidity and possible water drips into the bay.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 05-20-2015, 10:48 AM   #2
MAPerformance
Drives: Asphalt FRS
Pretty common to be honest with you. We typically apply high temp pain on a lot of our turbos before installing them. Doesn't really hurt anything, but you are right, kind of an eye sore.
MAPerformance is offline   Reply With Quote
Old 05-20-2015, 11:01 AM   #3
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
Its common, mine has it and its only been on the car for 3k miles. High heat + moisture will cause faster oxidation.
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
Old 05-20-2015, 11:09 AM   #4
STV3
Señor Member
STV3's Avatar
Normal. Every turbo I have had has done that.
STV3 is offline   Reply With Quote
Old 05-20-2015, 12:17 PM   #5
yomny
yomny's Avatar
wow.. really relieved to read this.. I have about 3k on the turbo and its just started to rust :/ We also just started to have very rainy days and I happen to have recently installed my vented hood so im sure that all contributed to a faster process. It just surprised me since for almost 2k it was spotless, it actually looked slightly oiled(center section) then boom...oh well. Thanks!
Old 05-20-2015, 01:28 PM   #6
#maverick#
#maverick#'s Avatar
If it really bothers you then you can probably get it ceramic coated but i cant be bothered lok
Old 05-21-2015, 06:40 AM   #7
yomny
yomny's Avatar
As long as it's normal I could live with it, getting a turbo blanket to reduce temps under hood so it'll draw attention away from it n
Old 05-21-2015, 08:28 PM   #8
Poodles
Drives: 2015 Series.Blue
Yep, normal. Cast iron likes to rust and the heat doesn't help matters. It probably was oiled to keep it from rusting (like brake rotors for example). Most OEMs will throw a heat shield over it so it's not noticeable.
My idea for a center arm rest / console cover / center cup holder ravenblackfrs Cosmetic Modification (Interior/Exterior/Lighting) 67 02-13-2016 03:00 PM
Why remove all the turbo topics from the turbo section!? DriftEightSix Forced Induction 22 04-08-2014 03:09 AM
Lug Nut Rust Wesley Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 17 04-14-2013 07:06 PM
Rust? even with rust proofing? Chinadian Issues | Warranty | Recalls / TSB 8 01-26-2013 04:15 PM
Rust already? Fugazi BRZ First-Gen (2012+) — General Topics 9 08-26-2012 02:36 PM
