Old 05-17-2015, 08:03 PM   #1
McJonald
McJonald's Avatar
Drives: 2013 Scion FRS
Frs SpecD Boomerang Headlights
I'm wanting to only have the turn signals on the headlights. I tried removing the bulbs from the stock turn signals but it does the quick blinking when removed. Does anyone know of a way to connect the wires so the turn signals are deactivated from stock location. Thanks for any help
McJonald is offline   Reply With Quote
Old 05-17-2015, 09:04 PM   #2
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
Just so I get this right, you don't want the turn signals to be active? You can just not wire the turn signals.
Chen is offline   Reply With Quote
The Following User Says Thank You to Chen For This Useful Post:
Wyattkb (05-17-2015)
Old 05-17-2015, 09:34 PM   #3
McJonald
McJonald's Avatar
Not the stock ones, the Specd's have them built into the headlight. Thanks for the productive comment
Old 05-17-2015, 09:43 PM   #4
Chen
Regional Moderator
Chen's Avatar
your just trying to lose the turn signal function in the headlight tho right?
Old 05-17-2015, 10:18 PM   #5
2SeeKU
Drives: Raven GT86 & Subaru WRX CS6
Just bypass the stock indicators? If the SpecD's source/tap from the existing indicators, then you could simply cut the wire going to the stock indicators AFTER the tap.
2SeeKU is offline   Reply With Quote
Old 05-18-2015, 08:53 AM   #6
McJonald
McJonald's Avatar
Thanks man, that's what I was thinking, but wanted to make sure it wouldn't cause another issue, thanks again
Old 05-18-2015, 11:00 AM   #7
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Cutting the connector will cause the same issue as taking the bulbs out. You need to get a hyperflash relay and then just take the bulbs out of the socket.
You don't really want to cut the wiring. If you ever trade the car in, the next owner will appreciate being able to change the headlights wihtout having to rewire the turn signals back into the car.
DustinS is offline   Reply With Quote
headlights, spec-d frs headlights
Boomerang light is out JJJMan75 Issues | Warranty | Recalls / TSB 15 07-24-2015 12:01 PM
BRZ ‘s “boomerang” LED strip mystery DrakeM BRZ First-Gen (2012+) — General Topics 114 05-05-2015 12:00 PM
FS: Spec D Black Boomerang Headlights with HID 4300k gutbomb Exterior Parts (Aero, Lighting, Etc.) 16 01-08-2015 10:04 AM
BRZ boomerang brighter ZOMBRZ Northern California 3 04-15-2014 08:31 PM
BRZ Headlight Running Light (the Boomerang) Schematic Acree Cosmetic Modification (Interior/Exterior/Lighting) 33 03-07-2014 03:03 PM
