Old 05-15-2015, 04:44 PM   #1
sprintertrueno86
sprintertrueno86's Avatar
Drives: 2018 BMW M2
How do I stop this box from rattling?
Is this the trans ecu?
Finally found the culprit to the light ticking/tapping noise that I've had for a long time. The noise will stop when I push against it with my foot.
Any suggestions on how to make it stop rattling?
Thanks guys.
sprintertrueno86 is offline   Reply With Quote
Old 05-15-2015, 04:50 PM   #2
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
Thanks guys.
Install a foot rest next to it and keep doing what you are doing
What is your foot keeping it from rattling against? Sounds like a strategically placed piece of foam or something would take care of it.
Scenic Driver is offline   Reply With Quote
The Following User Says Thank You to Scenic Driver For This Useful Post:
humfrz (05-15-2015)
Old 05-15-2015, 04:55 PM   #3
sprintertrueno86
Drives: 2018 BMW M2
It's not against anything. It's mounted pretty well so it's not loose or wiggling at all. But if I pushed against the box with my foot, the ticking noise stops.
Old 05-15-2015, 05:05 PM   #4
Scenic Driver
Does it matter which side of it you push on? If you unmount it and shake it does it rattle?
Old 05-15-2015, 05:19 PM   #5
sprintertrueno86
Drives: 2018 BMW M2
Don't know..
I'll try to loosen and tighten it again.
Old 05-15-2015, 05:39 PM   #6
nivek111070
Drives: 2014 GB Scoobie BRZ
try rubber washers to dampen vibration
nivek111070 is offline   Reply With Quote
The Following User Says Thank You to nivek111070 For This Useful Post:
sprintertrueno86 (05-15-2015)
Old 05-15-2015, 06:08 PM   #7
sprintertrueno86
Drives: 2018 BMW M2
Just fiddled with it and I also wedged some foam between some cases behind the trunk release controls while I was at it.
Will take a drive later and see if the problem is fixed.
Old 05-15-2015, 07:19 PM   #8
White64Goat
Duct tape.........what else is there?............
Old 05-16-2015, 03:58 PM   #9
sprintertrueno86
Drives: 2018 BMW M2
Problem fixed..no more tapping/ticking noise under the dash now. Unfortunately, rear left pillar or the rear deck lid area started rattling again...damn it, i'm always 1 rattle away from a rattle free BRZ.
Rattling in 2nd or 3rd at low rpms BigFatFlip Engine, Exhaust, Transmission 54 09-07-2015 09:54 PM
Rattling down the road... Harvey Scion FR-S / Toyota 86 GT86 General Forum 15 04-30-2015 04:03 PM
Undertray rattling Tainen Issues | Warranty | Recalls / TSB 2 09-29-2014 10:27 PM
PLM overpipe rattling. Tenchi Engine, Exhaust, Transmission 4 05-24-2014 03:07 PM
Rattling From The Clutch Wesley Issues | Warranty | Recalls / TSB 5 01-31-2013 10:27 AM
