Old 05-15-2015, 08:35 AM   #1
tweedbean
tweedbean's Avatar
Drives: White GT86
Tips on removing front drop links
Having a few issues with mine, the Allen key hole is rounded, is there a flat spot on the rear that I could get a spanner on to stop the thread spinning so I can then undo the nut?
Thanks
tweedbean is offline   Reply With Quote
Old 05-15-2015, 09:00 AM   #2
JozhGoober
Drives: 2020 718 GT4, 2013 FR-S (Turbo)
Mine rusted extremely fast, I ran into the same problem. I ended up just putting a big set of vise grips on the shaft (destroying the rubber boot) and using my impact wrench to remove the nut.
I installed new ones a month ago and they're already starting to rust!
JozhGoober is offline   Reply With Quote
Old 05-15-2015, 09:13 AM   #3
Tank
Mumbler
Tank's Avatar
Drives: Sensibly
Thanks
I had to do this recently as well. There was quite a bit of thread to work with on mine.
Clean the threads with a wire brush and use some penetrating oil on the nut if you haven't already.
Lock together a couple of nuts on the outer part of the bolt (preferably this part dry and clear of penetrating oil). This should give you something to hold a wrench/spanner on to keep the joint from spinning.
If it was as rusty as mine, you may have to work the nut back and forth and clean with a wire brush as you go.
Tank is offline   Reply With Quote
Old 05-15-2015, 01:55 PM   #4
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Try hammering a torx bit into the stripped allen keyway.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 05-15-2015, 02:58 PM   #5
wparsons
wparsons's Avatar
I had to cut mine, they always rust and suck.
flickr
WTB oem front end links P_say86 Want-To-Buy Requests 1 05-13-2015 09:30 PM
where to buy standard front end links from non dealer Shady195 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 04-04-2015 12:14 PM
WTB: Whiteline Front sway bar Links. Filipino Royale Brakes, Suspension, Chassis 0 08-06-2014 02:46 AM
22mm Perrin Front Sway Bar and End Links ramiram1984 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-18-2013 12:31 AM
Any tips on removing brake caliper olorin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-21-2013 10:47 PM
