Old 05-12-2015, 08:32 AM   #1
echan
Drives: Triumph TR6
Next CDC Autox ($10 Discount on the 2nd Slot) Saturday May 23rd at Winchester, VA
SATurday May 23rd Autocross
James Wood High School in Winchester, VA is the location of the next CDC autocross on SATurDAY May 23rd
Registration and tech inspection will be at 8:00 and will promptly close at 8:45 to try to accommodate the full field, while still giving 6 runs. You must be DONE by 8:45. So if you arrive at 8:00 you won't have a problem. Don't arrive at the last minute.
The event fee for the autocross is $30 for members and $40 for non-members at this event.
On-line Reservation System
Member reservations (or participants that will join the club upon showing up) for any events can be made at any time at www.capitaldrivingclub.com under the Schedule Tab. Open reservations for non-members for this event begin Friday May 15th.
$10 Discount on Second Slot
To help increase interested in this event, we are offering the following special.
For anyone paying for a second slot, the second slot will be $10 off. So if you are a member the second slot for a member will only be $20. If the second slot is for a non-member the cost will be $30 (rather than $40). A third slot would revert to the normal amount.
The second slot can be used the same driver (e.g. they would drive in two heats) or for a guest.
If you sign up for a second slot, just type "Second Slot" in the Notes Section. Otherwise, we may think you mistakenly submitted duplicate reservations.
Remember, to make a second slot, MAKE A SECOND RESERVATION (if the second slot is for a different person, type "Second slot for (type the name of the first slot person)".
-Several people used the second slot for a guest (some that never autocrossed with CDC)
-Many participants used the second slot to get 12 runs
-Some used the second slot to be a point autocross in the 6 morning runs (since only the first 6 counted for points) then treated the afternoon as a TNT by trading cars with other two slot participants
This offer is only extended for this event at James Wood HS on Saturday May 23rd, 2015. We like giving this discount but can't promise it at all events.
New Members
We will be accepting new members at this event. If you plan to join the club at this event, you may make a reservation at this time by doing the following:
1. Use "0" as the member number (a permanent number will be assigned to you after you join and you will get a temporary number for this event)
2. TYPE "I will be joining the club at this event" in the NOTES section when making you reservation.
The annual membership is $30 and is good for 12 months from the date you join.
If you have any comments or questions, please feel free to contact me.
Ed
echan is offline   Reply With Quote
Old 05-19-2015, 04:50 PM   #2
frslee
Just drive it
Drives: 13' FR-S
I may attend few events in June. I have a question though. Do you know what test & tune is? is it non-timed autocross where you can test your car?
frslee is offline   Reply With Quote
Old 05-21-2015, 03:13 PM   #3
echan
Drives: Triumph TR6
The Test and Tune Events are timed but points are not given. The main difference is that it cost $5 more but you get more runs (typically 10 rather than 6) and we don't have a grill to get food, and we break for lunch.
Old 05-21-2015, 05:18 PM   #4
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
The T&T is just as fun/competitive. CDC keeps an ongoing scoreboard for main events, T&T do not gain any points.
Also, T&T is typically only 2 heats, so it goes a lot faster.
SpectreRT is offline   Reply With Quote
Next CDC Autox ($10 Discount on the 2nd Slot) Saturday August 9th at Winchester echan Mid-Atlantic 0 07-29-2014 10:52 AM
Next CDC Autox ($10 Discount on the 2nd Slot) Saturday July 26th at Winchester echan Mid-Atlantic 6 07-25-2014 09:45 AM
Next CDC Autox ($10 Discount on the 2nd Slot) Saturday June 28th at Winchester echan Mid-Atlantic 3 06-27-2014 05:27 PM
CDC Autox $10 Discount on 2nd Slot SUN 6/15/14 Winchester, VA echan Mid-Atlantic 8 06-06-2014 09:49 AM
Next CDC Autox ($10 discount for 2nd slot) Sat 6/29/13 James Wood HS Winchester VA echan Mid-Atlantic 5 06-19-2013 07:40 AM
