Old 05-09-2015, 02:20 PM   #1
Harvey
Drives: Celica 5th Gen, Tiburon 04, GT86
Removing front fender
Any one have an illustrated step by step for removing the front fender? The GT86 or BRZ manuals don't have it, that's why I'm asking...
Harvey is offline   Reply With Quote
Old 05-09-2015, 02:49 PM   #2
joe strummer
I assume you mean front bumper. http://www.ft86club.com/forums/showthread.php?t=8788
I think I used this one when I removed mine.
joe strummer is offline   Reply With Quote
Old 05-09-2015, 03:02 PM   #3
Harvey
Thanks, but no, I clearly meant the front fender (the left hand side one in particular). It looks like it's mostly screwed on the frame, but I can't find any section in the floor shop manuals detailing how to remove a front fender (to repaint it).
Just to be clear, here's what I want to remove : http://www.carbongoodies.co.uk/Seibo...ers-10mm-Wider (this is just to illustrate the "front left fender", I by no means intent to use a non OEM one)
Old 05-09-2015, 04:24 PM   #4
Harvey
Some input here please guys... my local dealer seems to have messed up replacing the fender (after a minor accident), and before going back to look at it (I refused to pick the car up) I want to know what the correct fender replacement procedure is (also to know what I should inspect).
Old 05-10-2015, 02:50 PM   #5
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Well shouldn't the dealership have all the repair manuals? You are talking about a Toyota dealership right?
texasbound972 is offline   Reply With Quote
Old 05-10-2015, 02:56 PM   #6
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
Should be easy, I think you just need to remove the front bumper, and the side garnish and from there, it should just be bolts.
Old 05-10-2015, 03:34 PM   #7
Harvey
It is indeed a Toyota dealer, but from what I see in the repair manuals (I have GT86 Toyota TechDoc and the BRZ one too) there is no section explaining how to remove them. For example, removing the front bumper is well explained and illustrated, removing the garnishes/linings is also explained, but removing the fender is not. I suspect it's pretty simple, as Wes suggests, remove the bumper (not even sure this is necessary), remove the bottom lining, unbolt the fender and remove.
However, if someone has some experience with removing a front fender, I'd appreciate his input (to confirm, complete the above). Also, if someone has some pics of a GT86 with the front fender removed, it would be interisting.
Old 05-10-2015, 07:31 PM   #8
phastafrican
phastafrican's Avatar
Drives: 2013 Raven Scion FR-S
Front bumper off first. Should be about 10x10mm bolts total. 3 of top above wheel well, 2 by the headlight, 2 bottom side by the jack point, and 2 more holding the fender to the side of the body. Use a wrench from inside the opened door. remove the fender liner clips for it to slide out. Its a straight forward procedure, just follow the bolts
Emmanuel Baako: NASA-Southeast Race Control & NASA Florida Race Director
RaceCar:2013 Scion FR-S #986 NASA PTD || Tow:2011 Dodge Durango R/T
phastafrican is offline   Reply With Quote
The Following User Says Thank You to phastafrican For This Useful Post:
texasbound972 (05-12-2015)
Old 05-11-2015, 09:49 AM   #9
Harvey
Thanks for the procedure, the car's still at the dealer (the fender's been repainted), I'll see when it's back if all looks good.
DIY Request: Removing Side Fender Trim GH05T DIY (Do-It-Yourself) Guides 19 12-17-2017 02:11 AM
DIY REQUEST ON REMOVING FRONT FENDER werunbklynn DIY (Do-It-Yourself) Guides 2 05-26-2016 10:07 AM
removing chrome fender trim? zimzum Cosmetic Modification (Interior/Exterior/Lighting) 18 05-09-2016 10:15 PM
DIY: Removing and replacing fender garnishes/vents The Sentinel DIY (Do-It-Yourself) Guides 0 05-27-2014 06:47 PM
WTB: Raven front bumper plus front underpanel and passenger side front fender liner THEmailman Want-To-Buy Requests 1 04-20-2014 12:05 AM
