Old 05-09-2015, 11:12 AM   #1
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
Suspension help
Bc br, fa500, megan street, isc, d2, or tein street flex.
Yes i know that these are all cheapies. Im not looking to track the car or slam it. I go to the drag strip more than anything, yes i know its not a drag car but i like to drive my car the way i want to not how someone else says i should. I dont need to be lectured ive read alot of threads on here but just cant find the right input because of forum poison. Just want something nice to lower my car a bit and have better than stock handling. Thanks in advance.
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
Old 05-09-2015, 11:30 AM   #2
wparsons
wparsons's Avatar
Why coilovers? A good shock/spring combo is going to be cheaper and better than every option you have listed.
flickr
The Following 3 Users Say Thank You to wparsons For This Useful Post:
8R6 (05-11-2015), Decay107 (05-09-2015), tmcmullins (05-10-2015)
Old 05-09-2015, 11:37 AM   #3
sosick
fastest frs in sbg
sosick's Avatar
Because that means i would have to get top hats and assemble. Im lazy id like to just drop in and adjust. Btw does koni make regular struts now intead of inserts?
2014 firestorm frs
Old 05-09-2015, 11:39 AM   #4
sosick
fastest frs in sbg
sosick's Avatar
Im on my second frs and on my first one i had sportlines with stock struts and shocks i really liked them but not adjustable
2014 firestorm frs
Old 05-10-2015, 09:00 AM   #5
wparsons
wparsons's Avatar
The assembly would take like 5 minutes per shock, max. You'll spend WAY more time adjusting the coilovers than you will assembling a shock/spring/mount combo.
Koni has been making full struts for over a year now.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
sosick (05-10-2015)
Old 05-10-2015, 10:58 AM   #6
sosick
fastest frs in sbg
sosick's Avatar
Thanks ill look into it. Are konis height adjustable and what springs do you recommend? Sportlines?
2014 firestorm frs
Old 05-10-2015, 12:02 PM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
Try RCE yellow springs. Good combo with koni-s used by many.
Old 05-10-2015, 01:18 PM   #8
wparsons
wparsons's Avatar
They're not height adjustable. If you want sportlines then I would look at the Bilstein B8's instead. If you want to stay with Koni's I'd go with a spring with a bit less drop. RCE Yellows or Swift sport springs are a good choice.
flickr
sosick (05-10-2015)
Old 05-10-2015, 01:45 PM   #9
wootwoot
Drives: FRS
If you are too lazy to assemble top hats then you will be too lazy to set up coilovers properly. The second is much more difficult than the first.
wootwoot is offline   Reply With Quote
The Following User Says Thank You to wootwoot For This Useful Post:
wparsons (05-10-2015)
Old 05-10-2015, 03:06 PM   #10
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
If you want low out of a spring shock combo, RS-R springs do that quite well. Although there are better handling springs out there with less low.
The Following User Says Thank You to cdrazic93 For This Useful Post:
sosick (05-10-2015)
Old 05-10-2015, 06:28 PM   #11
sosick
fastest frs in sbg
sosick's Avatar
My sport lines had like a finger and a half. Thats why i like coils so i can just adjust to what loks good then align n drive
2014 firestorm frs
Old 05-10-2015, 06:29 PM   #12
sosick
fastest frs in sbg
sosick's Avatar
But i found from other ppl and through other members that fa is going to be my best bet thanks for the info guys
2014 firestorm frs
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-14-2015 05:06 PM
Air suspension aqua8701 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 43 03-09-2014 07:51 PM
FS: OEM BRZ Suspension midnight23 Brakes, Suspension, Chassis 10 07-24-2013 07:47 AM
fs suspension DanoFA20 Brakes, Suspension, Chassis 0 06-27-2013 09:02 AM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
