Old 05-07-2015, 12:14 AM   #1
Maboy_nelson
Maboy_nelson's Avatar
Drives: 2013 Asphalt Fr-S
Question Windows 8 OFT troubles
I currently have OFT running on the latest updated manager and have had the OFT working previously before and perfectly recognized by my computer. However now when I plug in my OFT to any of my usb ports, my computer doesn't recognize or even notice that something is plugged into the usb port. However I will plug my iPhone in and itll read perfectly so it cant be an issue about the ports. The OFT will light up with a mini picture in the middle of the OFT tablet however nothing becomes connected to the computer. I need serious help please!
2013 Asphalt FR-S : Invidia Q300 Exhaust : Invidia Front Pipe : Borla Unequal Headers : OFT Stage 2 Tune : RT-8 Matte Black 18' Wheels : 235/40/18 Michelin Super Sport Tires
Maboy_nelson is offline   Reply With Quote
Old 05-07-2015, 12:19 AM   #2
steve99
I dont think oft likes usb 3 ports, not sure if you can set them to usb 2 mode or try a usb 2 hub
Old 05-07-2015, 12:36 AM   #3
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
Check device manager to see if the device shows up, or if anything shows up at all. Maybe it's showing as an unidentified device because the drivers haven't installed themselves.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
Old 05-07-2015, 12:38 AM   #4
Maboy_nelson
Well here is the weird part about it, I'd had OFT working previously before on this same exact laptop with windows 8 and it connected fine. However that was 3 months ago, and now it doesn't connect at all, same laptop and still windows 8 so I don't understand what has changed and now I'm stuck in this situation where I can't manage my tunes and etc since my OFT doesn't connect
Old 05-07-2015, 12:39 AM   #5
Maboy_nelson
Checked device manager and it doesn't even show up
Old 05-07-2015, 12:59 AM   #6
steve99
windows 8 patch loaded off oft website ?
you using latest ofm software 1.19.x
Old 05-07-2015, 01:01 AM   #7
TelMinz
Rotary for the win
Drives: BRZ, FD3S RX7
Are you using the usb cable that came with the tablet? Find a different usb cable and try that.
TelMinz is offline   Reply With Quote
Old 05-07-2015, 01:18 AM   #8
Maboy_nelson
Yup everything off the website that's required, 1.19.x
I'm using the cable provided as well and even refreshed windows 8 to see if that would help at all either and nothing..
Old 05-07-2015, 01:41 AM   #9
steve99
you need a usb 2.0 port see below
http://www.ft86club.com/forums/showp...postcount=2259
Old 05-07-2015, 05:20 AM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
I somewhat suspect usb3 not working right due way it was often implemented in early motherboards via integrated 3rd party hubs for cost savings, instead of missing direct support in early chipsets, as after all shouldn't usb3 be backwards compatible and be able to drop speeds to usb1/2, if required? But if it's for any usb3 port .. i guess it should be highlighted in documentation for OFT, as issue might become more and more common, with older usb version ports being fazed out in newer pc-s/laptops, resulting in much more often "TABLET NOT WORKING, BAD!!" reports in let's say 5 years from now.
Old 05-07-2015, 06:22 AM   #11
TelMinz
Rotary for the win
Have you tried a system restore to an earlier point when oft worked?
oft.vishnu.tune.tunning, oftsupportgroup
Helmet troubles... Sonolin Tracking / Autocross / HPDE / Drifting 1 10-11-2013 07:10 PM
Manual Transmission troubles (tips are welcomed) Janunez90 Issues | Warranty | Recalls / TSB 14 08-07-2013 03:02 PM
Lug nut troubles Krait1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 07-14-2013 12:46 AM
Dealer Troubles shawnperolis Scion FR-S / Toyota 86 GT86 General Forum 39 02-23-2013 02:42 AM
iPod troubles mvhull Electronics | Audio | NAV | Infotainment 20 11-29-2012 07:01 AM
