Old 05-02-2015, 06:51 PM   #1
KingGT86
Drives: Raven FRS 2014
Fitiment
Quick question for you guys. Looking to get the ESM-007 18x8.5 et 35 cb 66.6( don't kno what cb means could someone explain?? Now my real question is what tires could I run that will fit without rubbing? I currently am riding on eibach sportlines.. Thank you ahead of time for the help!
KingGT86 is offline   Reply With Quote
Old 05-02-2015, 07:12 PM   #2
GarStar
cb is the center bore size. FR-s hub bore is 56.1 mm, you might want to get hub rings for 66.6 mm, that's up to you.
225/50/R18's are what I'm running on my 18x8.5's lowered 1 inch in the front. lots of room, no rubbing!
GarStar is offline   Reply With Quote
The Following User Says Thank You to GarStar For This Useful Post:
KingGT86 (05-02-2015)
Old 05-02-2015, 07:42 PM   #3
KingGT86
Are you sitting flush? Sportlines is 1.5 in I want to get as flush as possible without rub
Old 05-03-2015, 01:41 PM   #4
AlexWood
Drives:
Either a 215/45 or a 225/45 would be fine.
AlexWood is offline   Reply With Quote
The Following User Says Thank You to AlexWood For This Useful Post:
KingGT86 (05-04-2015)
Old 05-04-2015, 09:04 AM   #5
KingGT86
Thank you man
Old 05-04-2015, 09:04 AM   #6
KingGT86
Thank you man
I was going to go 245 that's to big I, guessing huh??
Old 05-04-2015, 10:25 AM   #7
AlexWood
Drives:
Sure, you could fit a 245 over an 8.5. Personally, a 235 would be the biggest I would go on an 8.5 for clearance purposes, but I tend to prefer a slight stretch on my tires anyway. It's up to you though, you can always google different tire sizes on your size wheels to get a better idea. There's plenty of pictures out there.
Old 05-04-2015, 12:02 PM   #8
AlexWood
Drives:
Old 05-04-2015, 02:49 PM   #9
KingGT86
Thanks man, and I'm jus trying to get it to where it sits as flush as possible with my 1.5 drop. I like the stretched look to.
Old 05-04-2015, 03:58 PM   #10
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
that is stretched for no reason on an 8.5.
i would go with a 245/40. that's the more appropriate size for an 8.5 wide wheel. your offset is low enough that you shouldn't have issues.
Jive Turkey is offline   Reply With Quote
