Old 04-30-2015, 02:48 PM   #1
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
Question New header gaskets when reinstalling?..
Hi guys,
I am going to pull my Tomei UEL header and OP off, and wrap them with DEI's Titanium stuff. I am wondering if I should buy new gaskets for this job? I have had the header on for roughly 5 months/5k miles, and this would be it's first removal. I know it's probably 'wise' but is it 'necessary?'
Thanks.
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
Old 04-30-2015, 02:59 PM   #2
edeekeos
edeekeos's Avatar
Also, I guess I should ask while I'm here: Is it even worth it to wrap the header/OP. As some of you may know, the Tomei UEL sits VERY close to the oil pan, and my oil temps have risen significantly, even with the heat shield material they send.
I know this is a HUGELY debated topic, but what are your guys' thoughts? I CAN'T afford ceramic coat at this time..
Old 04-30-2015, 03:32 PM   #3
Shady195
Drives: '13 10 Series FRS #1203
Are you tracking your car? If not then don't even bother.
However yes, you should always use new gaskets when re-installing.
Shady195 is offline   Reply With Quote
Old 04-30-2015, 03:42 PM   #4
edeekeos
edeekeos's Avatar
Yes, I do plan on hitting up Putnam Race Park a couple times this season, and I do quite a bit of aggressive road driving, or 'canyon carving' if you will. Also might look into some autox, my works holds events in the parking lot .
Old 04-30-2015, 03:50 PM   #5
kch
Senior Misanthrope
kch's Avatar
It's a pain in the ass to install UEL headers, so you don't want to have to do it twice. Use new gaskets just to be sure.
Old 04-30-2015, 06:39 PM   #6
edeekeos
edeekeos's Avatar
Makes sense..
Old 05-01-2015, 09:39 AM   #7
was385
Drives: MT WRB BRZ Limited, 2007 911s
This. Gaskets are cheap and easy to install when you already have everything off. But it's a pain in the ass if you have to take everything off just to install new gaskets because the old ones went bad. Not worth the risk.
was385 is offline   Reply With Quote
Old 05-01-2015, 02:33 PM   #8
edeekeos
edeekeos's Avatar
Yup, already ordered them. Thanks again fellas!
Old 05-01-2015, 03:57 PM   #9
burdickjp
Drives: 2013 ultramarine Scion FR-S
for what it's worth, the head to manifold gaskets are the same as the EJ, and there are many options for those, including multi-layer steel.
burdickjp is offline   Reply With Quote
Old 05-03-2015, 03:08 PM   #10
tracerit
Drives: '13 SSM BRZ Limited 6MT
What oil temps were you getting with the Tomei header on?
tracerit is offline   Reply With Quote
Old 05-06-2015, 02:17 PM   #11
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
Can anyone confirm with that?
Muaddib is offline   Reply With Quote
Old 05-06-2015, 09:38 PM   #12
burdickjp
I had pictures, but lost them when I reflashed my phone. I was pulling my OEM manifold to weld 4x EGT and 4x O2 bungs. I bought gaskets from the Toyota dealer for the endeavor. My friend had MLS EJ gaskets for his Impreza. They were dimensionally the same.
I'm curious if the Subaru part numbers are shared with anything. I have access to Toyota cross-referencing, but am not yet familiar enough with the Subaru stuffs to cross reference them.
Old 05-06-2015, 09:46 PM   #13
eurominican
Bringing Hachiroku Back
eurominican's Avatar
Drives: 2013 Firestorm FR-S
Where did you order them and how much were they? Im debating to buy the Tomei UEL header either new or used. The one Im about to pull the trigger will only be $100 cheaper than new and will have to buy the gaskets. What do you think, new or used (less than 500 miles)?
eurominican e u r o m i n i c a n
eurominican is offline   Reply With Quote
Old 05-07-2015, 01:50 AM   #14
edeekeos
edeekeos's Avatar
Used should be fine as long as there are no cracks or anything. The Tomei's are great quality, I have yet to hear of any failing.
I bought the Grimmspeed Gaskets. They were like $25 or so from ft86speedfactory.
Where can I get new header gaskets for cheap? MikeM7 Engine, Exhaust, Transmission 28 03-15-2015 02:20 PM
OEM radiator - help reinstalling TemeCal Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 02-03-2015 07:55 AM
Exhaust and header gaskets Cu0ngsayz Want-To-Buy Requests 4 10-22-2014 12:47 AM
Exhaust header / manifold gaskets (Subaru part number) ft_sjo Engine, Exhaust, Transmission 1 07-15-2013 09:24 AM
Header gaskets Motordyne Engine, Exhaust, Transmission 1 06-23-2012 04:31 PM
