Old 04-25-2015, 10:42 PM   #1
GOT FR-S
Drives: 2013 Scion FR-S (Firestorm)
Help please. Vortech blower issues - impeller
This is the upgraded V2 kit. Oil feeds from motor instead of independent resevoir.
Pretty sure this is not normal. This is first time running the blower since Vortech did a complete overhaul on it 7months ago cars been parked for winter and had the motor built. All new internals and seals. Yet this doesn't seem normal. Any thoughts??
Yes i know not clamped down properly. Was trying to figure out oil crap.
Watch "Vortech impeller oil leak" on YouTube
Vortech impeller oil leak: [ame]http://youtu.be/Q6lFwuD8JTo[/ame]
Vortech SC. Rev Work Header, Perrin over pipe, Invidia resonated top pipe, Greddy EVO3 exhaust, Perrin Light weight crank pulley, Gofast bits lightweight waterpump & alternator pulleys, Perrin Trans & Shifter mount, MTec Shift springs. Cusco rear diff brace, 1pc Alum Drive Shaft (Drive Shaft Shop), ATC performance clutch & Flywheel, Whiteline Positive traction bushings. Grimspeed hood struts. EcuTek Tune.
GOT FR-S is offline   Reply With Quote
Old 04-26-2015, 09:32 AM   #2
DJCarbine
Thupercharged
DJCarbine's Avatar
Says video is private
2013 FRS
Vortech V3 11psi
Old 04-26-2015, 12:01 PM   #3
GOT FR-S
Try now. Didn't realize I had loaded as private.
Old 04-26-2015, 08:48 PM   #4
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Try a shorter, more direct drain. And make sure crankcase pressure isn't allowing the oil to drain properly. I had nothing but issues with vortech blowers on my VW. Even after rebuilds
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 04-27-2015, 12:17 AM   #5
GOT FR-S
I figured it out. I was a retard. I didn't remove the drain cap. It blended with the fitting. No more leaks. Thanks for the suggestion though.
Old 04-27-2015, 08:13 AM   #6
puma
crew chief
puma's Avatar
Drives: Race car FR-S
lol good one
puma is offline   Reply With Quote
FS: Vortech Supercharger Tuner Kit with Rebuilt Blower F1point4 Engine, Exhaust, Bolt-Ons 3 02-02-2015 09:59 AM
Installing Vortech SC, ran into a couple of issues HRTROB Forced Induction 24 07-08-2014 12:54 PM
ac blower cfm question shif7i7down Electronics | Audio | NAV | Infotainment 0 05-29-2014 01:54 PM
Vortech blower a bit of noise? Sniper2606 Forced Induction 25 07-17-2013 07:11 PM
who wants to see inside of a vortech blower :) charged86 Forced Induction 20 04-14-2013 07:46 PM
