Old 04-21-2015, 12:06 PM   #1
Ddreder
Ddreder's Avatar
Drives: 2013 FR-S, 1990 Miata
Finally bought some springs
So I finally pulled the trigger on buying some springs because my car sits really high with the 235/50r17 tires I put on. Anyways after much debate and deciding that I really wanted the rear slightly lower than the front I went with the RS-R super down springs from redline360. I am probably going to have a shop put them on as I really dont want to wack a fender with the impact gun when I inevitably become impatient with the springs..
My question is.. After doing some research I keep seeing that if you lower your FRS more than 1 inch that you should get LCA's. I was just wondering if that was entirely true? These springs say they will drop approximately 1.2in in the front and 1.4in in the back so I am a little worried. Maybe @Tcoat can chime in on this but I really dont want to have to put LCA's on the car..
Any help would be much appreciated guys! Also the bissel carpet cleaner worked great!
Ddreder is offline   Reply With Quote
Old 04-21-2015, 12:11 PM   #2
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
http://www.ft86club.com/forums/showthread.php?t=45554
I'm sure RCE can easily answer and technical questions you have regarding suspension do's and don'ts in that thread.
MokSpeed is offline   Reply With Quote
The Following User Says Thank You to MokSpeed For This Useful Post:
Ddreder (04-21-2015)
Old 04-21-2015, 12:16 PM   #3
gramicci101
Off Topic
Why did you put 235/50's in your car? That's an inch and a half taller than the OEM tire.
The Following 5 Users Say Thank You to gramicci101 For This Useful Post:
8R6 (04-23-2015), drewbot (04-21-2015), golfyankee2121 (04-24-2015), Jesse36m3 (04-21-2015), JohnJuan (04-21-2015)
Old 04-21-2015, 12:25 PM   #4
Ddreder
Ddreder's Avatar
I wanted a meaty tire.. I got a good deal on them and didnt realize they would be THAT tall lol although when I lower it the car is going to look very mean.
Old 04-21-2015, 12:52 PM   #5
thill
No matter what you are going to want to find a good alignment shop to get your car within spec. I am guessing because you dropped it pretty low you may need lca's to account for any negative camber that might need to be adjusted for that an alignment can't. But until you know your alignment specs it is kinda hard to know what you will need to do.
Old 04-21-2015, 01:05 PM   #6
Timmy_Jones
Spun
Drives: 23' Supra
Among other problems, like your speedo and odometer...I don't know if this will fit with a lowered car. Report back, would like to see finished pictures.
Timmy_Jones is offline   Reply With Quote
Old 04-21-2015, 01:11 PM   #7
Ddreder
Ddreder's Avatar
The tires fit pretty ok now. I can get a litle rub on the front drivers side if I go full lock to the left (which I rarely do) but I think I am going to cancel my order and go with a spring with less drop to avoid buying LCA's. the H&R springs are 1" in the front and 1.2" in the back and I think that will be the best compromise.
The Following 2 Users Say Thank You to Ddreder For This Useful Post:
Tcoat (04-21-2015), Timmy_Jones (04-21-2015)
Old 04-21-2015, 01:18 PM   #8
Timmy_Jones
Spun
Drives: 23' Supra
I think the springs are fine...I would re-think the tire size choice.
Old 04-21-2015, 01:19 PM   #9
Timmy_Jones
Spun
Drives: 23' Supra
Take a look here: http://www.frsproject.com/tire_size.php
The Following User Says Thank You to Timmy_Jones For This Useful Post:
Old 04-21-2015, 02:02 PM   #10
I have the stock LCAs but am also on stock tires so am not putting as much stress on them. Like was already said get a good alignment but wait a couple of days for everything to settle before you do.
You will love the look!
Old 04-21-2015, 02:31 PM   #11
xmadror
Drives: BRZ Sport Tech 13
I'm no expert on lowering a car but I'd think that if you already rub at stock height going lower will certainly not help.
I would suggest to rethink that tire choice first.
xmadror is offline   Reply With Quote
Old 04-21-2015, 02:33 PM   #12
Ddreder
Ddreder's Avatar
Have you noticed any extra inside tire wear on the rear?
Old 04-21-2015, 02:42 PM   #13
Not a thing and I already have 25,000 miles on the car. Wear looks good and everything lines up just fine. Not sure what effect the taller tires would have (beyond the obvious rub issues) as they could certainly increase the angle.
Old 04-21-2015, 03:13 PM   #14
Ddreder
Ddreder's Avatar
Hmmm well I think I might just end up YOLOing it and dealing with the camber since they have already shipped the springs and getting them back is proving difficult.. Note to all, Redline360 ships VERY FAST. Make sure you order the right thing the first time lol
WTB: RCE yellow springs or eibach prokit lower springs fr/brz Gt86-turbo Want-To-Buy Requests 0 03-08-2015 03:18 PM
FI Guys: Were you more excited when you bought your car, or when you bought boost? husker741 Forced Induction 28 02-25-2014 03:57 PM
Anyone bought Litchfield springs? (outside of UK) JDM-dono Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 11-16-2013 07:37 AM
just bought my FR-s! rosgonz Scion FR-S / Toyota 86 GT86 General Forum 28 07-15-2013 11:29 PM
Best store bought or online bought wax ThatManAnt Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 16 03-12-2013 09:32 PM
