Old 04-16-2015, 01:02 AM   #1
RMP
Drives: 1992 Isuzu PuP, 2014 FR-S
is the ECU a Subaru or Toyota unit?
Title pretty much says it all. Much thanks to anyone who has the answer.
RMP is offline   Reply With Quote
Old 04-16-2015, 01:37 AM   #2
TJ3000
Drives: MT Raven Black FRS
It's a Toyobarunit
TJ3000 is offline   Reply With Quote
The Following User Says Thank You to TJ3000 For This Useful Post:
nickw14 (04-20-2015)
Old 04-16-2015, 01:37 AM   #3
steve99
subaru.
no you cannot just swap out an ecu, they are a coded set ECU Imobiliser and Dash Cluster plus FOB keys.
you either swap all components in set or obtain new ecu then get toyota/subaru to re-code the security set.
RMP (04-16-2015)
Old 04-16-2015, 08:31 AM   #4
Kayysonie
Badass Member
Drives: 2014 SWP BRZ Limited
subaru.
Well. ECU is from Denso, which was part of Toyota at one point. Again, they can probably just label the ECU subaru cause it is built in Subaru plant. Just like any other stamping on drivetrain parts in a Toyota GT86. Everything is labeled Subaru.
Edit: Addition to what I said. All imobilizer and alarms are very similar to any toyota..the locking beeping sound is the same as the camry, corolla, and prius.
Im pretty sure Subaru and Toyota worked with Denso with the control of the whole vehicle.
So recap. Its actually really hard to tell.
Kayysonie is offline   Reply With Quote
Old 04-16-2015, 12:59 PM   #5
KoolBRZ
KoolBRZ's Avatar
It's Toyota hardware with software programmed for/by Subaru. Toyota Techstream logs into it seamlessly. The real nutcracker though is the automatic transmission control unit. I haven't seen any posts about anyone cracking into it yet.
Old 04-16-2015, 08:45 PM   #6
robr
Drives: 2013 FRS, with boost by ATS Racing
...and Tundra. My boss and I can't tell which car is beeping if he hits his '07 Tundra button at the same time I hit my FRS one. It actually might be the same as my wife's IS250..I'll have to give that a listen again.
As said, Toyota's Techstream works without fail.
Oddly enough though, it is wired like a Subaru. At least the door lock circuit is (WRT to locking the doors with a turbo timer running).
robr is offline   Reply With Quote
Old 04-16-2015, 09:33 PM   #7
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
I'm inclined to say Subaru, it's similar to the electronics in the 2015 WRX ECU, but that doesn't say too much since Denso probably makes that too and they have more of a say in how the low level electronics work as long as it works the way Subaru/Toyota wants it to.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
Old 04-17-2015, 01:30 AM   #8
Poodles
Drives: 2015 Series.Blue
D4S system is Toyota's, so I'm inclined to say it's purely Toyota for this...
Old 04-17-2015, 01:59 AM   #9
steve99
The ECU is very similar hardware denso (similar microprocessor) and runs similar software (with added bits for DI/PI to the Subaru Forester, XV ECU, this was why the romraider/tactrix guys were able to "crack" it so quickly.
Old 04-17-2015, 02:51 AM   #10
Kaotic Lazagna
Drives: GR Corolla
Toyota TechStream was able to change the default recirculation on my Monogram HVAC from on to off (fresh air).
Old 04-22-2015, 10:39 PM   #11
Paiser
Drives: Scion FR-S Monogram (Whiteout)
If you got anything from the answers, it's toyoburu
Paiser is offline   Reply With Quote
Old 04-22-2015, 11:05 PM   #12
Turdinator
Señor Member
Turdinator's Avatar
@RMP why does it matter?
1974 TA22 Celica
2013 86 GT
Old 04-24-2015, 07:10 AM   #13
rlpaul
Drives: point A to point C. Screw point B!
tl;dr
It's a Denso unit. Toyota and Subaru both use Denso units. So its a moot point trying to label it as a Toyota or Subaru.
rlpaul is offline   Reply With Quote
Nurburgring Video of Subaru BRZ Coupe / Subaru FR-S / Toyota FT-86 Shows off Handling Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 113 11-21-2020 01:02 PM
STI ~ Subaru | TRD ~ Toyota | JDM Lanyards & Toyota Emblem Overlay for Scion FR-S! KI_ZN6 Groupbuys 173 01-15-2016 01:56 PM
Toyota 86 GTS stock head unit won't turn on. ZN6_88 AUSTRALIA 3 04-23-2014 08:50 AM
Toyota sized Kenwood Navigation unit Laurie Electronics | Audio | NAV | Infotainment 36 09-26-2012 12:07 PM
Subaru/Toyota Coupe spotted in Socal with Subaru Plates owsiu Scion FR-S / Toyota 86 GT86 General Forum 150 05-25-2011 10:27 PM
