Drives: 2013 FRS asphalt
switch back issue
alright, I just bought a FRS and it already had the switch back LED's installed and now the right bulb is always yellow (not white) and I don't have a turn signal now (because it just stays solid) anybody have any ideas on what it could be? it worked fine before...
Drives: 2013 FR-S, Hot Lava
Sounds like a loose connection.
what would make it default to a solid yellow tho?
Drives: Scion FR-S 10 Series #2263
A loose connection.
On a more serious note, try swapping the left/right switchbacks to rule out a defective unit. If the problem follows the bulb, just buy a new bulb, unless you are an EE type of guy and can repair the teeny electronics on the switchback. If the problem stays on the right side...you have bigger problems. |
okay man, thanks a ton
| FS: 9005 LED&7443 LED Switch Back bulbs | Rican_D | Exterior Parts (Aero, Lighting, Etc.) | 6 | 01-16-2015 12:35 AM |
| There is a new window switch available to fix the passenger auto up/down issue | Subie | Issues | Warranty | Recalls / TSB | 51 | 04-13-2014 02:34 PM |
| ZN6 Headlight DRL switch back Conversion | lvl up | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 11-14-2013 09:05 AM |
| Do Switch Back LEDS Work On The BRZ ? | PhreshhWun | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 08-01-2013 07:14 PM |
| Switch Back LEDs for BRZ | DNAPoPo | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 02-07-2013 08:11 PM |
