Drives: LR BRZ Limited
Anyone venture to guess what happened to my modded tails?
Blacked housing mod i did here: http://www.ft86club.com/forums/showthread.php?t=85630
Looked like it was clear lens when i installed it But a few days later in the Socal Sun, this happened. ![]() it happened on the other tail light as well and in the same circular fashion. it looks like scratches but i opened the passenger side tail light and it didnt exactly feel like scratches. i'm not sure what happened here. and not sure why they both have the same circular patterns in the same locations. Any ideas? |
Drives: 2013 GBS BRZ Limited
Did you put them in the oven to open them?
Drives: 2013 White-Out FRS
Is it deep in the housing? I'm guessing the heat from the circle lights of the tail lights itself burned into the housing due to chemicals from the mod or idk I'm just saying random shit but yeah. The circle shape could've been from the light and heat.
I live my life one quarter-pounder at a time.
did not bake these at all. i used a solder with a copper tip to open these up. then sealed it up with 3M Windo-Weld Ribbon Sealer.
Gold Member
Drives: 14' SWP BRZ MT limited
looks like chemical vapor form the window weld. I know when I've used some types of glue similar to super glue it will leave a white haze on plastic near it
Drives: BRZ Limited
after painting the taillights, you should cure them by putting the painted tails in the oven at low heat for about 30 min. This prevents any smoke inside the lens created by the heat.
Drives: 2014 BRZ MT (Sold); 2006 V70R
Vapors from paint or glue reacting with the plastic.
'14 BRZ LTD MT DGM
Drives: FRS
looks like an eye
I'm betting it's vapor from your glue or paint that attached to the housing
#10 |
Drives: ‘13 FRS
| toyotas next joint venture... | cdrazic93 | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 06-17-2014 01:43 AM |
| Venture Shield vs Xpel Clear bra? | tintumz22 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 10 | 05-30-2013 11:19 PM |
| Toyota and GM Joint Venture | Dragonitti | Other Vehicles & General Automotive Discussions | 19 | 03-31-2011 03:34 PM |
