Old 06-13-2012, 03:05 PM   #1
Re~Mix
Re~Mix's Avatar
Drives: 13' Scion FRS MT
Stop n Go / Highway Meter MT Protocol
I have only been driving MT for about 2-3 weeks now and have a question or two regarding procedure for stop-n-go traffic and highway entrance meters (ie. Driving at speeds of 2-3 mph)
As of now I don't really fully enter first gear since I am only inching so to speak.
Basically, I let off the clutch partially and give it some gas until it engages a bit and moves forward. Pretty soon after I press in the clutch and coast and repeat as necessary. I just wanted to make sure this was an OK practice since i was warned not to use the clutch too much (or press it partially) while hitting the gas or when the car is in gear. Same goes for reverse in parking lots where I'm using the clutch and brake in tandem.
Re~Mix is offline   Reply With Quote
Old 06-13-2012, 03:21 PM   #2
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
What you are doing seems about right.
Save your transmission by staying in gear (less shifting from neutral to first) as much as possible.
Save your clutch by using the downhill slope to roll and catch up with traffic. If you're lucky you can just use the brakes and parking brake to keep up with slow-moving traffic.
If you have to apply some gas, keep the rpms as low as possible. Your clutch won't wear too badly if you're giving it sub-1.5k rpm rolls. It's the high friction of faster rpms and partial clutch that burn it up quick (you'll smell it, trust me). Basically, if the car isn't jerking forward or chirping tires, you're probably not launching too hard. Once you have enough momentum, feel free to depress the clutch completely again and just roll till you have to brake.
If you're really lucky, you'll get those 10-15 mph rolls that you can just sit in second gear and be a-okay without any left-foot magic. I have the habit of pulling the parking brake once I'm stopped for over 5 seconds (or if I know I will be).
The advice about 'riding the clutch' applies when you're moving otherwise (like using the clutch as a foot-rest). I know it sounds crazy, like "who would do that?" but.. some people do.
eriktherod is offline   Reply With Quote
Old 06-13-2012, 03:27 PM   #3
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
Yeah it's unavoidable to slip the clutch sometimes if you are stuck in traffic, and there is no harm if it is at low RPMS, although it will heat up eventually if you are doing it constantly and that could cause some issues. Just try to keep it to a minimum, and never use the clutch to hold yourself on a hill.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 06-13-2012, 06:25 PM   #4
Re~Mix
Re~Mix's Avatar
Thanks for the input guys, glad to have some piece of mind in knowing I am doing things properly.
Unlike most drivers, I do try to maintain a speed / coast as opposed to riding the bumper in front of me to maintain some sanity and go easy on the drivetrain.
Old 06-13-2012, 07:39 PM   #5
ducks
Drives: car
i do the same thing. even more so since switching to a manual. leaving space in front of you has a net positive effect on traffic anyways
ducks is offline   Reply With Quote
Stop sale on FR-S DarrenDriven Scion FR-S / Toyota 86 GT86 General Forum 13 05-29-2012 01:49 PM
Does it have MPG meter? 8987846 BRZ First-Gen (2012+) — General Topics 34 05-18-2012 01:35 AM
Highway complaints ZetaVI NY / NJ / CT / PA 7 02-10-2012 12:01 PM
Please... Stop... Me.. moda3 Great Lakes 4 12-09-2011 11:51 AM
