Old 04-08-2015, 12:22 PM   #1
Superjoe69
Keep OEM USB w/ after market head unit?
I'm picking up a BRZ on Friday and planning to swap out the OEM had unit for something better. Is it possible to keep the USB in the center console functional?
Superjoe69 is offline   Reply With Quote
Old 04-08-2015, 01:26 PM   #2
Chimera
Drives: FRS
http://www.ft86club.com/forums/showthread.php?t=8595
or even better
AX-USB-35EXT (http://www.sonicelectronix.com/item_...USB-35EXT.html)
Old 04-08-2015, 01:40 PM   #3
keithr
keithr's Avatar
Drives: 2014 BRZ Limited (DGM)
Short answer, yes.
If you want to keep the OEM plug(s), you'll need an adapter.
Metra AX-TOYUSB or PAC Audio USB-TY1
If you want to keep the OEM AUX functional as well, it comes off the 28-pin connector. You can get a harness from here: http://ae64.com/aftermarket-HU-install-parts-2012FT.htm
Scroll down to the section on the 28-pin harness.
If you go that route, you can get the AX-TOYUSB directly from him as well.
The other option, as given by @Chimera, is to pull out the factory USB/AUX port module and just replace it with the one he linked to.
In fact, I did this exact thing in my BRZ with my Pioneer HU, and I can confirm that it is a 100% perfect drop-in replacement fit. It couldn't be any easier.
And, wouldn't ya know it, I just happen to have an extra AX-USB-35EXT. I'll gladly sell it to you for a very fair price, just PM me.
keithr is offline   Reply With Quote
Old 04-08-2015, 01:41 PM   #4
Superjoe69
Fantastic, just what I needed. Thanks!
Old 04-08-2015, 02:06 PM   #5
P3tras
Drives: Subaru BRZ '13 WRB
Other solution is to simply cut off stock connectors on USB/AUX harness and solder standard USB and RCA (or any other) connectors. That is what I have done and it works fine
P3tras is offline   Reply With Quote
Anybody know ... what head unit this is? chaoskaze Electronics | Audio | NAV | Infotainment 3 12-21-2014 06:44 PM
FR-S Head Unit in BRZ? gatsbysghost Electronics | Audio | NAV | Infotainment 6 04-22-2014 07:52 PM
FR-S Head Unit in BRZ? gatsbysghost Electronics | Audio | NAV | Infotainment 0 04-20-2014 08:21 AM
BRZ Nav Head Unit Sojhinn Audio/Visual, Electronics, Infotainment, NAV 16 11-03-2013 06:02 PM
head unit in GTA excited86 Electronics | Audio | NAV | Infotainment 1 06-18-2012 07:42 PM
