Old 04-07-2015, 09:21 PM   #1
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Precision 4854b mfs need info
Alright I've searched earth and sky and can't find a single thing on the max psi this turbo could see before exceeding peak efficiency. I've contacted precision with no luck. I've seaeched around Google and on other forums but no luck. Precision doesn't return my emails and I think I read somewhere they don't do compressor maps. A little help from someone with some reliable info and some knowledge on boost maps? I read the turbo is good for about 360, not sure if that's crank estimate. Thanks.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 04-07-2015, 10:49 PM   #2
mrk1
Drives: Sterling BRZ Ltd
I'm not sure how you would determine this with out a compressor map. I cant say I've ever seen a map from Precision, I know the equipment to create the maps is very expensive. 360 would be a very general crank hp number.
If you can locate a compressor map, plotting points isn't terribly hard. There are online calculators for it.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
yomny (04-08-2015)
Old 04-08-2015, 10:48 AM   #3
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
LOL Precision.
Old 04-08-2015, 11:59 AM   #4
yomny
yomny's Avatar
lol yeah I know.. its what I've read that they don't want to spend the money on creating maps for blah blah reasons. I figured the only true way to do so is with a compressor map. I've been looking around at other 48mm wheels but I know that's not accurate. I guess if they rate the turbo at 360(not sure if wheel or crank lol) we could calculate the amount of lbs of air(please don't quote me on any of this I as I don't know the terminology correctly) it would move at max efficiency but this still doesn't give the psi. I read that its like 10hp per lbs of air or something of that aspect so 360 would mean 36lb of air @ ??
I'll see if they reply to my emails.. its not the end of the world if I can't figure it out. I just thought it'll be good to know the max to push with my current setup to choose fueling supply adequately.
Old 04-08-2015, 12:16 PM   #5
MAPerformance
Drives: Asphalt FRS
Precision rates their turbos at WHP. Which seems to be fairly accurate. I am making 322whp on pump with my 4854, I would imagine 360whp should be doable on E85 (or more boost). While tuning my car, I accidentally hooked up the boost controller the wrong way, and it hit 20psi during a pull, and honestly, it wasn't making that much more power than our original 12psi run. It was picking up more torque, but maybe 5-10whp gain from 12-20psi. Again, there could be a lot of variables going on at the time as well. I would imagine somewhere around 25-28psi would be pushing out of it's efficiency range. (this is a non scientific guess)
MAPerformance is offline   Reply With Quote
The Following User Says Thank You to MAPerformance For This Useful Post:
yomny (04-08-2015)
Old 04-08-2015, 12:33 PM   #6
yomny
yomny's Avatar
20-28 I don't know why I had in mind that 15psi or so would be near its efficiency limit. Good to know though and thanks for the reply.
Old 04-08-2015, 12:53 PM   #7
MAPerformance
Drives: Asphalt FRS
Well, you still might be right. But I think if I tuned my car on E85, we could have made more power past 15psi. However, I never tested it, so I could be completely wrong lol. I mean, stock Evo turbos can run 27-28psi before they run out of steam, same with the stock STI turbo's. I would say the 4854 is in the same ballpark of those...
yomny (04-08-2015)
Precision LEDs has it ALL when it is time to get better lights!!! Precisionleds Exterior Parts - Lighting 391 07-14-2015 04:04 PM
Props, kudos and + 1 to Precision Autobody Tromatic Northwest 0 07-25-2014 05:52 PM
Precision Dynamix fog light wrapping jay_ Cosmetic Modification (Interior/Exterior/Lighting) 4 03-23-2014 02:25 AM
Precision LED Ironsquid User/Vendor/Sponsor Reviews, Feedback, Comments 0 04-08-2013 11:08 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 10:09 PM
