Old 04-05-2015, 10:11 PM   #1
Manji
Toyotas don't have boxers
Manji's Avatar
Drives: GTV86, ISF, TE27
1UZ swap - running.
Got quite a bit done over Easter. Basically ran out of things to do until shops are reopen.
Only things left are:
Intake pipe from airbox to throttle body
One of the AC lines needs to be extended
Buy and fit accessory belt
Bonnet pins
Put bung in gearbox where speedo sensor usually goes
Swap current muffler to Perrin 3"
Fluids
Will get all of that done this week. And next week am taking it to HPA labs to get the motec wired and tuned.
Manji is offline   Reply With Quote
The Following 14 Users Say Thank You to Manji For This Useful Post:
andrew5826 (05-11-2015), Calum (04-06-2015), chaoskaze (04-07-2015), civicdrivr (04-13-2015), DAEMANO (04-08-2015), Dimman (04-05-2015), Draco_PR23 (04-06-2015), flippy (04-07-2015), Guff (04-06-2015), hmong337 (04-07-2015), raven1231 (04-10-2015), Sportsguy83 (05-10-2015), Teseo (04-11-2015), Valentino (04-08-2015)
Old 04-05-2015, 10:50 PM   #2
glide003
Drives: Red 86 GT
Can't wait to see this thing running.
Sent from my HTC_0P6B using Tapatalk
glide003 is offline   Reply With Quote
Old 04-06-2015, 12:00 AM   #3
DieselDog
Shift it or lose it
DieselDog's Avatar
Drives: 2014 FRS, 2003 Celica GT
I see you have a snap on cordless ratchet! Ive had mine since they came out and its been great. Awesome for tight spaces and not fumbling with air lines.
DieselDog is offline   Reply With Quote
Old 04-06-2015, 02:09 AM   #4
mikko86
Drives: Scion
possible to get it weighed when its all done as well?
mikko86 is offline   Reply With Quote
The Following User Says Thank You to mikko86 For This Useful Post:
Old 04-06-2015, 07:13 PM   #5
Manji
Manji's Avatar
You and me both!
Originally Posted by DieselDog View Post
I see you have a snap on cordless ratchet! Ive had mine since they came out and its been great. Awesome to tight spaces and not fumbling with air lines.
One of the best tools ever.
Yes I intend on doing this. Have already corner weighed it pre conversion, and will be doing the same after conversion.
The Following 2 Users Say Thank You to Manji For This Useful Post:
hmong337 (04-07-2015), Valentino (04-08-2015)
Old 04-07-2015, 04:46 PM   #6
Starkiller
Drives: 2013 Scion FR-S 10 series
Please use ITB's on this setup!! They sound so wicked! The response you gain isn't bad either. Are you doing a lightweight rotating assembly?
Starkiller is offline   Reply With Quote
Old 04-07-2015, 09:59 PM   #7
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Sigh, i might do this sooner than i thought ...
Old 04-08-2015, 06:30 AM   #8
Streetthrowback
Drives: 2015 brz
Interesting
Streetthrowback is offline   Reply With Quote
Old 04-08-2015, 06:51 AM   #9
WesleyG
Drives: 2014 Satin White Pearl GTS auto
What intake manifold is that? most 1UZ I have seen have the throttle body on the side on the intake.
2002 MR2 Spyder 2zz-GE Apexi PFC PPE Race header 8500 RPM of FUN
2014 37J 86 Auto
WesleyG is offline   Reply With Quote
Old 04-08-2015, 01:34 PM   #10
carlitosway6891
Drives: white out project fr-s
depending on the year of the engine, the intake was either on the side of the manifold or directly in front of the manifold. newer year UZ motors had the throttle body on front of the intake
carlitosway6891 is offline   Reply With Quote
Old 04-08-2015, 06:45 PM   #11
Armageddon
Drives: 05 tC, 13 Fr-S
What transmission (and adaptor used if manual) was used for this swap? Also, would like some info on the engine and transmission motor mounts. Also any canbus programming tips if you are using stock gauges would be lovely. We would love as much detail as possible.
Armageddon is offline   Reply With Quote
Old 04-10-2015, 02:55 PM   #12
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
The VVTi version (1998+) has the front-facing intake manifold
uspspro is offline   Reply With Quote
Old 04-10-2015, 08:59 PM   #13
jdmblood
jdmblood's Avatar
Drives: white subaru brz
Really interesting build sir
jdmblood is offline   Reply With Quote
The Following User Says Thank You to jdmblood For This Useful Post:
aagun (04-14-2015)
Old 04-10-2015, 10:38 PM   #14
Manji
Manji's Avatar
I've spent half my Saturday on forums, updating similar threads in other places. So going to instead do it from now on on a fb page.
Feel free to follow if you want. Ask questions etc.
Means I can upload things easier. Not answer the same questions over and over etc.
https://www.facebook.com/pages/Panhard/1376455312683672
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
2JZ swap? jordydiaz Engine Swaps 44 05-21-2015 10:19 PM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 11:14 AM
BRZ Swap!!!! EnviedIke Engine Swaps 59 07-30-2014 06:32 PM
2jz swap p3raltaboi Scion FR-S / Toyota 86 GT86 General Forum 54 06-11-2014 08:09 PM
