Southern California SoCal
Old 04-05-2015, 12:31 AM   #1
laley81
Scion FR-S
laley81's Avatar
Drives: Scion FR-S 2013
Backup camera won't trigger?
Hello I just recently installed a back up camera and followed every step possible on a link from this forum. My issue is that for some reason my camera won't trigger when I put it on reverse. I currently have a bespoke premium headunit and have a 2013 FR-S. I have had the camera for a week with no luck. So all of of a sudden my camera decided to work for about 5 minutes. Later on it stopped working again. What am I doing wrong. Any help will be welcomed. Thx in advance.
laley81 is offline   Reply With Quote
Old 04-05-2015, 12:33 AM   #2
laley81
Scion FR-S
laley81's Avatar
Do I need to buy this harness??
Description:
Add a backup camera to your car or truck! This harness connects a 12-volt Backup Camera to the stock Toyota/Subaru/Scion head unit. The stock head unit is wired with a 6-volt output. This harness uses a 6-volt relay and the 12-volt accessory power provided to the stock head unit to provide a 12-volt output and composite video input for any standard automobile backup camera.
The harness connects in the place of the 16-pin connector pictured here. It will also ground the E-brake input into the head unit, allowing use of some additional funcionality while the car is in motion.
You will receive:
-1 Backup Camera Harness(Includes connections for 12-volt jumper harness, 16-pin head unit connection, Composite Video input, Relay, and 12-volt output lead)
Old 04-05-2015, 12:33 AM   #3
laley81
Scion FR-S
laley81's Avatar
-1 12-Volt splice harness(T-harness)
-1 Relay (6-volt input coil)
-1 Butt connector to connect 12-Volt output from harness to the backup camera
The harness is 100% plug and play. No splicing the stock wiring harness. Does not disturb stock appearance. The only exception is the Reverse Trigger Wire. Most vehicles have this wire pre-installed. If yours does not, the included pin slides into the stock connector, but the wire other end of the wire must be spliced to a reverse signal(such as the reverse light or the signal wire located in the driver's side kick panel). A splice connector will be included for completing this connection.
Old 04-05-2015, 11:08 AM   #4
Weapon86
Weapon86's Avatar
Drives: 2014 Scion FRS monogram series
it would probably be your reverse trigger wire having some loose connection on one end. What brand is your backup camera?
Weapon86 is offline   Reply With Quote
Old 04-07-2015, 05:08 AM   #5
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
I used a harness off some ae-86 site, the guy makes all sorts of harnesses and takes orders with his 1998-style webpage. Simple install, like post above, i too would check the tap for your reverse trigger. Tap it right, dont half-ass it either.
. ck
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
Old 04-07-2015, 02:55 PM   #6
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
update?
Backup camera G8mou Northern California 28 01-08-2015 01:25 AM
Q&D backup camera VR46 Electronics | Audio | NAV | Infotainment 8 09-05-2014 10:13 PM
Backup Camera Raven23 Electronics | Audio | NAV | Infotainment 6 07-16-2014 02:50 PM
PnP Backup camera - BRZ? Skurj CANADA 1 04-10-2014 01:33 PM
Backup Camera Help husker741 Electronics | Audio | NAV | Infotainment 2 02-13-2013 01:04 AM
