Old 04-03-2015, 07:03 PM   #1
Stay Fresh Car Care
Stay Fresh Car Care's Avatar
Drives: STI
Engine bay cleaning!
Cleaning your engine bay as never been this easy.
Link to full article: http://www.stayfreshcarcare.com/#!detailing-guide/c1ip2
SF Team,
Follow us on Instagram @stay_fresh_car_care
Use the code FT86 at checkout to save 10% off your next order at www.stayfreshcarcare.com
Stay Fresh Car Care is offline   Reply With Quote
The Following User Says Thank You to Stay Fresh Car Care For This Useful Post:
keithr (04-03-2015)
Old 04-03-2015, 07:22 PM   #2
vividracing
vividracing's Avatar
Wow, that's awesome.
Would it work if I didn't have a high pressure sprayer and I had some painted engine components that I didn't want to get chipped away and used a hose with a trigger sprayer attachment? I could do this before I show my car.
-RyanG
vividracing is offline   Reply With Quote
Old 04-04-2015, 11:20 AM   #3
Stay Fresh Car Care
Drives: STI
-RyanG
Ryan,
Yes the gunk and grease easily comes up by just wiping away if you do not have a high pressure sprayer.
We like to keep our hands fresh here
Old 04-04-2015, 06:11 PM   #4
JMoody
Drives: 2016 FR-S
Is there anything we would need to cover up or protect on our cars? Im afraid to ruin electronics or something with a pressure washer
Current: '16 Halo FRS
JMoody is offline   Reply With Quote
Old 04-04-2015, 08:21 PM   #5
babydriver
Hit the road and I'm gone
babydriver's Avatar
While you're at it, when using the two bucket method for washing your car's exterior, use distilled water for the wash and the rinse. The stuff costs under a buck a gallon at Wal-Mart or the local grocery store and having no impurities prevents water spots. I work in a medical testing lab and I BELIEVE in its use. Tap water has all kinds of chemicals, added and otherwise, that can leave deposits on your car.
Really, it's a buck a gallon. Why not do it? I mean, you don't have to go crazy and get deionized lab water or anything like that.
Slip, slidin' away.
Old 04-04-2015, 08:32 PM   #6
xxscaxx
Drives: 2013 SWP BRZ
Just don't directly spray down senitive areas, like the ECM/Wiring, alternator, fuse box, battery, etc. Lightly pass those areas. Just be smart about it and you shouldn't have to cover anything.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
Stay Fresh Car Care (04-05-2015)
Old 04-04-2015, 08:40 PM   #7
housecat
Computer Scientist
housecat's Avatar
Drives: 2014 BRZ Limited
I actually already do this, put distilled water in a pump sprayer and rinse the tap water off car. However, I still have to dry the car. Otherwise, the distilled water collects dust from the air, and leaves spots on the car once dry. There isn't much difference between drying tap water or distilled water, so I've stopped doing this to save a couple bucks a month.
Keep calm and drive safe
housecat is offline   Reply With Quote
The Following User Says Thank You to housecat For This Useful Post:
Old 04-05-2015, 01:21 PM   #8
Stay Fresh Car Care
Drives: STI
Yes it would totally defeat the purpose in buying the water, since you are going to be washing with the hose. (Unless you are some how washing it with the paid water)
Old 04-05-2015, 07:20 PM   #9
babydriver
babydriver's Avatar
I'm not suggesting you don't have to dry the car! I was suggesting that using distilled water in the soap solution and the 2nd rinse bucket for the washing sponge will reduce deposits on the car's finish from impurities in the water. If you live in a place like Austin, where the water has so much lime in it that you can sculpt the dried residue, it's a good idea. Also, I suspect that chlorine in the water attacks the wax/finish a little and probably dulls it a bit. Of course, that part doesn't matter if you are planning to rewax, but trapping impurities beneath the wax could be an issue, depending on the water itself. Softer water, less of a problem, since the soap works better.
Slip, slidin' away.
Old 04-05-2015, 10:36 PM   #10
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
nice
i actually just cleaned the bay today, i used some degreaser but still have to give it a nice scrub.. first major bath since winter is over!
Old 04-06-2015, 12:03 AM   #11
housecat
Computer Scientist
housecat's Avatar
You're right, and there's always going to be places that water reaches that you can't dry where deposits will build up. A cheaper alternative to distilled water might be to use ONR (Optimum No-Rinse) to soften your tap water. A $20 bottle of ONR can make you 64 gallons of soft water, but how effective it is against very hard water is questionable. I think distilled water would be better.
Old 04-06-2015, 10:42 AM   #12
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Actually, if the water is really a problem, a deionizer or water softener might be a good idea if you have some money for it.
First, start with a meter to detect dissolved solids:
TDS Meter
Then buy an inline or portable water softener or deionizer:
Portable Water Deionizer
In-Line Water Softener
Old 04-06-2015, 10:21 PM   #13
babydriver
babydriver's Avatar
TDS Meter
We have a water softener. All it does is reduce the pH of the water so that soap works better. It doesn't remove any of the minerals at all. For that you need a filter or a distiller.
Also 300 bucks will buy you over 300 gallons of distilled water at Wal-Mart. At 1/2 a gallon a car wash using the twin bucket method, that's 300 car washes minimum. At once a week that's about 6 years worth of car washes. Once every two weeks, and you're likely to sell and/or wreck the car before you reach 300 dollars.
Let me guess; you work for or own Griot's Garage...
Slip, slidin' away.
Old 04-06-2015, 10:52 PM   #14
Black Tire
Black Tire's Avatar
We haveLet me guess; you work for or own Griot's Garage...
Nope, and don't be such a jerk. Griots garage is just where I could find the information and products.
Engine bay cleaning? Shad0ez Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 09-05-2015 09:23 AM
Newb question on cleaning engine bay swift996 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 7 02-09-2014 08:34 AM
What to cover in engine bay cleaning? l0aded Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 15 07-25-2013 05:45 PM
Detailing/Cleaning Engine Bay Jeffboyarrdee Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 17 06-17-2013 09:35 AM
Engine bay cleaning tips? Chewie4299 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 9 06-11-2013 10:34 PM
