Old 04-02-2015, 01:04 AM   #1
wootwoot
Drives: FRS
After cat-less header....
It seems common knowledge on the forum that a catless header is one of the best ways to free up extra power. It also seems common knowledge that replacing the over pipe, front pipe and mid pipe bring little gains if you plan to keep the secondary cat in the system. My question is as follows: after you install a catless header are there any other exhaust parts that will net you solid gains once tuned? Or is it best to install the catless header and tune the car with the rest of the exhaust stock?
wootwoot is offline   Reply With Quote
Old 04-02-2015, 02:48 AM   #2
ramiram1984
Drives: 2016 STi DGM
You've been a forum member since 2012...and you're asking this question...
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
The Following User Says Thank You to ramiram1984 For This Useful Post:
iamdaspoon (04-02-2015)
Old 04-02-2015, 03:08 AM   #3
akahenry
akahenry's Avatar
Drives: '18 STi
zzzzzzzz
akahenry is offline   Reply With Quote
Old 04-02-2015, 04:46 AM   #4
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Wider Mid pipe if you don't mind the rasp
Carlitoz3 is offline   Reply With Quote
Old 04-02-2015, 10:57 AM   #5
wootwoot
Drives: FRS
I ask because it all seems to be conjecture.....
Old 04-02-2015, 11:35 AM   #6
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Well, fp with catless header will net you appreciable gains over just catless header alone with tune, but after the cats, there won't be any appreciable gains.
Catbacks and axlebacks are aesthetic parts only used to improve visuals and exhaust note. That's it. Parts that hold the cats or are forward of the cats are your performance parts, of which the catless header (or a catless downpipe, if you're running turbo) is the most significant.
^GT5 Replay Photo Mode^
Old 04-02-2015, 11:55 AM   #7
wootwoot
Drives: FRS
I agree that is the common knowledge. And thank you for your response.
Do we have any dyno information showing the net gains of a mid pipe after a catless header has a already been installed? Maybe catless header and stock mid pipe vs. catless header and test pipe. My search was unable to find something of that sort other than vendor dyon's, which I trust very little.
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 11:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 06:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 09:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 05:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 11:34 PM
