Southern California SoCal
Old 03-31-2015, 09:27 AM   #1
mystic
mystic's Avatar
Drives: 2020 BRZ PP CWP
Anybody running conversion spacers?
I pulled off some TE37's off a friends R33 this morning to find out that the wheel cast has a 5x100 stamp on it. I got pretty excited but when I checked the sticker on the backspacing it said 5x114.3 -This made sense as my knowledge with the skyline is that it does not have a 5x100 bolt pattern. With a little bit of hope still, I tried to test fit it on my car anyways since I couldn't find a tape measure around but came to the sad conclusion that it indeed wouldn't fit. They are 17x9.5 +12 all around.
I'm not knowledgable in this area and I'm hoping somebody with experience can help me figure this out. Also, I should note, I was basically offered the wheels if they would fit onto the car. My question is... Should I run conversion spacers? Is it safe? will it bring issues? will this size and offset specifically even 'work'? (if anybody has ever tried before). Maybe it's my paranoia, but any feedback would be appreciated. If all I have to do is buy some adapters to make em fit, I don't mind having some fresh Volk's on my car.
Selling them and purchasing wheels in 5x100's is not an option. If they were to sell, then the proceeds would go back into the shop. Just an fyi.
mystic is offline   Reply With Quote
Old 03-31-2015, 02:29 PM   #2
PradiG
Drives: Fr-s
Any adapter you will will lower the offset. It also depends on what type of fitment you want.
An 11mm project kid adapter would reduce the offset the least, but you'll have to shave your stock studs because they will hit the back of the wheel. With an 11mm adapter your wheels would become 17x9.5 +1
An 15mm adapter would essentially be the same, however its more aggressive, and you'd still be shaving your stock studs. Your wheels would be 17x9.5 -3
A 25mm adapter would be big, but however you will NOT have to shave your stock studs. However it will be a huge amount of poke. Your wheels would be 17x9.5 -13
hope that helps. A lot of people are running conversion spacers, mainly a lot of rocket bunnies.
PradiG is offline   Reply With Quote
Old 03-31-2015, 02:59 PM   #3
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Don't adapters, in adding length to the hub offset, add more stress onto the wheel bearings?
^GT5 Replay Photo Mode^
Old 03-31-2015, 03:12 PM   #4
8R6
8R6's Avatar
Drives: FRS
yes (basically same as large spacers)
8R6 is offline   Reply With Quote
Old 03-31-2015, 03:12 PM   #5
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
Those are going to poke like hell. Just buy the right wheels.
Jesse36m3 is offline   Reply With Quote
Old 03-31-2015, 10:12 PM   #6
mystic
mystic's Avatar
Thank you. This actually helped a lot and makes perfect sense.
Old 03-31-2015, 10:13 PM   #7
mystic
mystic's Avatar
Probably so.
Old 04-01-2015, 07:43 PM   #8
guslucatero
guslucatero's Avatar
Drives: 2014 WhiteOut
Currently I have running 25mm spacers with the conversion to 5x114.3
18x10.5 +22 rear
18x9.5 +34 front
guslucatero is offline   Reply With Quote
Old 04-02-2015, 04:25 PM   #9
murselyfe
murselyfe's Avatar
Drives: It's black.
I'm running 11mm Project Kics adapters. Everything @PradiG stated is valid. And yes, you will need to trim your stock studs.
#becauserocketbunny
2013 Subaru BRZ Limited- Crystal Black Silica
murselyfe is offline   Reply With Quote
Old 04-02-2015, 04:37 PM   #10
murselyfe
murselyfe's Avatar
Drives: It's black.
This is a common misconception. Wheel bearings have a tendency to fail prematurely when you install spacers and/or wheels that are not hub-centric to our cars. This causes an uneven stress once the wheels begin to rotate, essentially wearing the bearings out of round.
Stay hub-centric for both the spacer to hub and spacer to wheel and you will have no issues.
Old 04-08-2015, 06:24 AM   #11
Celigts
Celigts's Avatar
Drives: 2014 Toyota FRS
I run 25mm conversion spacers...hub centric. Zero issues and been approx 1k miles.
Celigts is offline   Reply With Quote
Project kics conversion spacers Kwise1 Scion FR-S / Toyota 86 GT86 General Forum 3 08-25-2014 12:17 AM
Conversion spacers popos1907 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 08-01-2013 01:24 AM
Anyone Here Running the Kics 10mm 5x114 Conversion Spacers? slava Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 07-24-2013 01:41 AM
Anyone running spacers yet Toyobaru808 Hawaii 1 07-12-2013 02:14 AM
