Old 03-22-2015, 12:02 PM   #1
Brooklyn
Brooklyn's Avatar
Drives: 2014 DGM BRZ
Icy roads - spun out into ditch
Hi guys, so last night driving home on a two lane divided highway (ditch in middle) travelling around 90km/h in 6th gear, I encountered increasingly snowy and wintery conditions and before I could turn off the exit into the nearest town, the back end broke loose.
THE SPIN CYCLE:
First, I was turned about 30 degrees to the left. So with my foot off the gas after noticing the slide, I tried to counter steer to the right. This led to temporary correction but then led to a slide facing the opposite side. With another attempt to counter steer to the left, the car slowly spun to the left 180 degrees facing oncoming traffic while still travelling forward (my guess is at a speed around 70-80km/h). I was facing an oncoming car going the same rate of speed as I was while I was backward. Eventually the car slid sideways onto the left shoulder where I heard tire screech and the car eventually spun into the ditch (composed of grass, dirt and snow) at approximately 60 km/h (again, a guess).
THE AFTERMATH:
Car came to a halt in the ditch. Immediately smelled some sort of rubber smell. I assume this was the tires. But could it be something else? I didn't hear any collision or damage under the car but who knows?
Two dash indicator lights were on: cruise control light in orange (which I think indicates a malfunction), and check engine light, which is still on. To clarify - I was not in cruise control at the time of spin.
Car was able to start again, and I idled about 1.5 hrs to keep warm while waiting for a tow. Car able to move at slow speeds. Did not try at higher speeds. No physical damage to body as far as I could tell.
Questions:
- Does the check engine light automatically come on after a jolt?
- What things should I be aware of - I'm guessing I need an alignment check but what other things could have happened?
- One of my concerns is when I was travelling forward while facing backwards, would my car have stalled if I was in gear, or would my wheels still be spinning forward? Is there any damage that this could have done to my transmission?
- My biggest concerns are transmission and suspension and any high priced ticket items.
- The car is now in the lot of the nearest Subaru dealership to be checked out. Is there anything I should be aware of? Anyone know the procedure for inspecting cars in cases such as these? Thanks guys for your input.
TLDR: icy roads leads to fish tail, leads to spinning out into ditch, leads to rubbery smell and check engine light. Car at foreign dealership waiting for diagnosis. What to know, what to check for?
Brooklyn is offline   Reply With Quote
Old 03-22-2015, 04:51 PM   #2
HeadBanger
HeadBanger's Avatar
Drives: '14 Subaru BRZ
Why was your traction off?
I've driven at higher speeds with about 8 inches of snow and traction would just prevent wheel spin or any angle.
Life's too short to drive a boring car
HeadBanger is offline   Reply With Quote
Old 03-22-2015, 05:49 PM   #3
Astro
Drives: Stock today, Not tomorrow
what?? your traction works? Mine dosnt work for shit. I can put the car sideways with in on in the snow
Astro is offline   Reply With Quote
Old 03-22-2015, 07:09 PM   #4
JRCmx
Drives: Ridgeline
Seeing his the car idled for 1.5 hrs I think all would be fine.
My concern with any car in a spin would be the motor cycling backwards. Any number of things could be damaged by this happening.
Unless you hit something our the car dropped off the road hard I would not think anything would be wrong.
If the dealer says something is wrong ask to see some sort of proof before authorizing any work.
Check your manual for the cause/reason for the idiot lights.
Next time you spin, both feet in. Once you reach opposite lock, clutch in lock up the brakes (you become predictable in the direction of travel) and wait till you come back around (if you don't hit something 1st) and try to recover it again. Brake bias and or ABS may help right you with this.
Also, use what ever drive aids that are available in those conditions.
Unless you want to try to achieve that epic drift again.
JRCmx is offline   Reply With Quote
The Following User Says Thank You to JRCmx For This Useful Post:
Brooklyn (03-22-2015)
Old 03-22-2015, 07:24 PM   #5
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
I was in a situation similar to this. The snow kept getting heavier and heavier while I was driving on the highway, and plows/salt trucks hadn't yet come out. Accidentally drove outside of the tire tracks from the car ahead of me, and that spun my car from the right lane all the way to the jersey barrier on the left side. Luckily I was able to drive it home with no damage. Luckily there was already a couple feet of snow against the barrier to soften the impact.
If the car was able to move on it's own, I'd imagine your transmission is fine. Your suspension is probably also fine, though an alignment wouldn't hurt. The dealership will probably just do a test drive and scan the OBDII port for error codes.
Are you sure you didn't just accidentally hit the cruise control stalk while spinning around?
2013 Asphalt Scion FR-S | Jackson Racing Supercharger | KW V3 | Enkei RS05RR 18x9.5
campy is offline   Reply With Quote
Old 03-22-2015, 07:37 PM   #6
kberkel
kberkel's Avatar
Next time you spin, once you reach opposite lock, clutch in lock up the brakes (you become predictable in the direction of travel) and wait till you come back around (if you don't hit something 1st) and try to recover it again. Brake bias and or ABS may help right you with this.
. Especially with snow. Your car is probably fine, or else no one would ever track the car if a simple spin out caused problems.
kberkel is offline   Reply With Quote
Old 03-22-2015, 08:11 PM   #7
Brooklyn
Brooklyn's Avatar
Thanks for that. Yeah I'm most concerned about transmission or motor cycling backwards but from what I could remember, and/or my understanding of physics, I didn't get any traction while sliding backwards...so I'm assuming I was just sliding. Again, these are my worries. I'll figure out what codes the dealer pulls tomorrow when they are open hopefully.
Old 03-22-2015, 08:16 PM   #8
Brooklyn
Brooklyn's Avatar
Dont think I did. While I was waiting I tried to find the orange cruise control light explanation in the manual and I remember it saying something about 'malfunction'.
I hope so. I just don't remember if I disengaged the clutch in my spin. Last known gear I was in was 6th. So I'm wondering if being in gear while spinning out did any damage...
Old 03-22-2015, 08:22 PM   #9
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
It's totaled....lol
You'll be fine. The computer is just mad at you. Clear the codes and drive on.
ntron1 is offline   Reply With Quote
The Following 4 Users Say Thank You to ntron1 For This Useful Post:
Brooklyn (03-22-2015), dodj (03-22-2015), Eski (03-24-2015), Pkush (03-23-2015)
Old 03-22-2015, 08:23 PM   #10
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
Sounds terrifying! I'm glad you and your car is ok.
-May I ask what tires you had on? And did you clutch or brake at any point during this?
Old 03-22-2015, 09:04 PM   #11
Brooklyn
Brooklyn's Avatar
- stock tires (just recently took my winters off) but a freak snowstorm happened and the rest is history
- no brakes as I was trying to correct the fish tail. I guess I should have clutched in to disengage power at some point?
Originally Posted by ntron1 View Post
It's totaled....lol
Thanks dude. hoping for the best.
Old 03-22-2015, 09:41 PM   #12
Kayysonie
Badass Member
Drives: 2014 SWP BRZ Limited
You had your cruise control on when cruising 90kph? When the car sees you spin with the cruise control, it disables it thus turning orange. The check engine probably was caused by stalling the car when you spun out? Were you running a torque app? Usually when you start your car while the app is running OBD2, it can cause a check engine for communication issue.
Kayysonie is offline   Reply With Quote
Old 03-22-2015, 10:21 PM   #13
lionbacker54
lionbacker54's Avatar
Drives: 2013 WR Blue 6MT BRZ
even though you were traveling backwards, i doubt if the wheels were actually turning backwards. your tires had lost traction, so it was just spinning. so i would doubt there's any damage to the transmission or engine.
second, your BRZ is 2014, right? so it is under warranty even if there is any damage. your dealership actually has an incentive to find and repair anything, because subaru pays for it. i had some leather cracking on my steering wheel and my dealership was super happy to order a new one for me and replace it on subaru's tab.
lionbacker54 is offline   Reply With Quote
Old 03-22-2015, 10:47 PM   #14
D_Thissen
D_Thissen's Avatar
Not all dealerships are that nice. Some might say 'You weren't driving for the conditions, we can't warranty it'. Crazy yes, but I know its happened to a few people. It took a buddy of mine 6 months to get his driver and passenger windows replaced after they started getting vertical scratches in them.
Spun out and hit a curb... JohnAyySays Issues | Warranty | Recalls / TSB 54 12-09-2013 11:59 AM
Toyota Tells Dealers They Can Ditch Scion, Then Shows New Concepts whitefrs Scion FR-S / Toyota 86 GT86 General Forum 1 08-20-2013 03:32 PM
Spun out now a CEL Noob4Life Issues | Warranty | Recalls / TSB 10 03-31-2013 12:02 AM
Red BRZ owners, chance to ditch the 'stash! coyote AUSTRALIA 4 07-27-2012 07:44 AM
