| CANADA Canada |
Drives: '14 Brz
2014 brz sweating stock shocks
Both front shocks showing signs of oil seepage down the main shaft after the seals, never had springs on them or been tracked/autocrossed/abused. Went to local subaru said shocks were "bone dry". Manager looked as well as "grand master tech" both said were bone dry. attaching pic. Mind you I'm also an apprentice and asked to show my concern as to where it was leaking. Request ignored. (pic attached)
Drives: BRZ Sport-tech
Bone dry
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
Looks bone dry man
and if that's Budd's you went to, I don't think they would play around (IMHO) |
Drives: '14 Brz
The deep blackness is from oil on the shock, if you touch the shock oil is apparent on your finger, was just wondering if anyone has had any similar experiences. The shock should be in the same condition as the spring (covered in dirt) which it evidently is not.
Is it actually oil from the shock, or is it road grime? Was the car oil sprayed at all? Do all four look the same?
Drives: '14 Brz
Just the front, both in same spots on front. It's evidently leaking which is sad, rears are dry. It was lightly sprayed but I rotated my wheels earlier in the sesson and it was not there
I find it very hard to believe they're leaking and the oil is spreading that uniformly around the whole body. Typically it would just be a drip or stream, not a totally uniform coating.
Drives: '14 Brz
So your struts look the same I take it then? There's no other area the oil would come from and the oil pattern is similar to most vehicles with blown struts. Not trying to be rude just frustrating considering second thing this week including car being hit
| stock springs better shocks? | blown | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 03-03-2015 03:31 PM |
| 2013-2014 SCION FR-S OEM SPRINGS STRUTS SHOCKS ASSEMBLY FRS BRZ 5K MILES TESTED $299 | STS-V | Brakes, Suspension, Chassis | 10 | 08-31-2014 09:58 AM |
| Pro-Kit on stock shocks | B-R-Z | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 03-21-2014 10:05 AM |
| Sportlines on stock shocks <4k miles | stefmiesterb | Brakes, Suspension, Chassis | 2 | 11-18-2013 10:52 AM |
| FS: Stock OEM front shocks and springs | stefmiesterb | Brakes, Suspension, Chassis | 0 | 07-29-2013 01:55 PM |
