Old 03-18-2015, 06:56 PM   #1
t.chk
Drives: Subaru BRZ Limited
Torklift Central Ecohitch for BRZ/FRS!
Hello all, a while back Kask2.0 was making concealed hitches for the BRZ/FRS/GT86 and I was lucky enough to get one before he and the thread disappeared.
http://torkliftcentral.com/trailer-h...cohitch-invisi
But! It appears Torklift just created one that is strikingly similar and equally hidden hitch adapter! I found it while looking up hitches for my Impreza and figured to sign in and share.
I am living vicariously through all of you since I had to sell my BRZ.
Below is a picture from Kask2.0's unit if you want to compare notes.
Kask2.0's:
t.chk is offline   Reply With Quote
The Following 3 Users Say Thank You to t.chk For This Useful Post:
djdnz (04-20-2015), Lonewolf (07-26-2015), SOAZ (04-13-2015)
Old 04-20-2015, 06:35 AM   #2
i-engineer
i-engineer's Avatar
Drives:
Does anyone have any experience with this hitch? Looks like it hides away well, just a tad more expensive than the uhaul one.
i-engineer is offline   Reply With Quote
Old 04-29-2015, 09:41 AM   #3
t.chk
I did not have torq's hitch, the one I had was very similar. It can be used to tow small trailers <1000lbs. I used it for a bike carrier and it worked quite well. My only complaint if there was too much weight on the hitch it would rest on the stock exhaust and resonate so I took a hammer to it and made the room needed.
I believe torqlift fixed that problem with theirs but I would contact their support to be sure. if you have a smaller muffler in the back you are good.
the hitch completely disappears since you can physically remove it. That is a great selling point for those of us that like a clean butt
Old 07-26-2015, 08:44 AM   #4
Quentin
Drives: ‘16 4Runner, ‘19 Corolla HB
I'm considering this one for my FR-S. I have an Ecohitch on my Rav4 and had one on my Prius v. They are very well made and fitment is excellent. I'm not too crazy about having to take my rear bumper off or the fact that I'll be adding 30 to 50 lbs to the rear of the vehicle permanently. This or the tow bar rack... decisions, decisions.
Quentin is offline   Reply With Quote
Old 07-26-2015, 12:06 PM   #5
White64Goat
It also looks like that it won't fit if you have a rear diffuser.........
Old 07-26-2015, 12:18 PM   #6
Quentin
Not a problem for me. TRD exhaust is the only non stock item I have back there.
Old 07-27-2015, 08:57 PM   #7
t.chk
If you know a quality metal/custom shop you can have them make you just the drop down adapter. bring them the original for template and leave with an additional for the difference in drop height.
Should be do-able, good luck!
Old 10-24-2015, 11:11 PM   #8
evilz
Drives: 2016 FRS
Listed for up to 2015 models. Before I buy one, can anyone think of why this wouldn't work on 2016 models?
evilz is offline   Reply With Quote
Old 10-26-2015, 09:53 AM   #9
t.chk
Only thing I can think of is if they attach the bumper to the car using different bolt pattern. Or if the exhaust muffler sits further rear than previous years.
Only other thing you may need to do is trim the bottom of the bumper for the hitch to drop through. (I trimmed mine just to make it easier to take on and off but didnt have to)
Old 10-26-2015, 11:35 AM   #10
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
Have you asked Torklift about 2016? They're nice folks. I have one of these on my 2013 and it's great.
TofuJoe is offline   Reply With Quote
Old 10-26-2015, 05:47 PM   #11
djdnz
1337
Drives: 2013 BRZ WRB S/C
I want this hitch, but I don't understand why it's so expensive compared to the alternatives. I have a curt now but I don't like being able to see it.
djdnz is offline   Reply With Quote
Old 10-27-2015, 02:04 PM   #12
t.chk
They are very well crafted and look nicer than others. Also they seem to be made with better materials. I had a generic hitch on my Impreza and got their hidden hitch for it. Theirs weighed twice as much and the flanges were twice as think (full disclosure: the torklift hitch was rated 350/3500 and the generic I had was rated 200/2000).
The biggest selling point is that it is not visible, that is why it is so much more money. They are the only place that makes them like that (from what I found when I had my BRZ).
Old 01-13-2017, 07:21 PM   #13
pwest
Drives: 2014 Silver BRZ Premium
My son and I installed one earlier today in about 1.5 hours on my stock '14 BRZ premium (I mostly just watched). The job was easier than expected: pop off about 6 plastic pop rivets (I bought a couple of special tools to make that easier) and two screws, remove the bumper cover, unbolt the 4 bolts and 2 nuts that hold the bumper on, hang the hitch on the two protruding studs, put the bumper back on and install with the provided bolts, torque, put the bumper cover back on. Everything fit, no drilling, bending, filing or snaking nuts through the chassis. I got mine with the removable 2" receiver and it's a beast.
-Phil
pwest is offline   Reply With Quote
ecohitch, hitch, torklift, trailer hitch
Central Coast FRS/BRZ Yellow_Jacket Southern California 9 09-24-2014 11:09 PM
Central Georgia! gusbarragan Southeast 77 05-18-2014 09:04 PM
Shops in Central NJ? TomT2411 NY / NJ / CT / PA 3 04-03-2014 05:17 PM
anyone in central pa with a tune? milenko11 NY / NJ / CT / PA 0 01-25-2014 01:52 PM
Central FL Owners! VADER Southeast 18 12-06-2012 08:48 PM
