Old 03-14-2015, 08:16 PM   #1
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
Nameless cam plate problems..
Didn't think it was possible to have a defective piece of aluminum. I installed this last night to fix a very minor oil leak at the cam plate, and the Nameless part made it WAY WORSE. Followed the install video exactly, and it's leaking worse than ever before. Tried to reinstall it two more times with the same result. Is it possible the plate or o-ring is defective? Do I need an additional gasket to make this work? Any thoughts?..
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
Old 03-14-2015, 10:19 PM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
Pull the o-ring and check it for cracks/deformation. If it seems that the o-ring is rubbing off on your hand, it's likely you got one that isn't compatible with your oil.
The Following User Says Thank You to Calum For This Useful Post:
edeekeos (03-14-2015)
Old 03-14-2015, 10:45 PM   #3
edeekeos
edeekeos's Avatar
I'll pull it off and check again. I'm running Pennzoil Platinum 5W20.
Old 03-15-2015, 01:32 AM   #4
humfrz
Well, I don't have any first hand knowledge with this part ..... but, I'd clean it up real well, make sure the "O" ring is seated good ....... AND goop it up with some gasket seal, put it back on, being sure to tighten, to spec., the bolts, uniformly.
Betcha it won't leak .....
humfrz
Old 03-15-2015, 01:44 AM   #5
JB86'd
JB86'd's Avatar
Drives: JAWS
What kind of sealant are you using?
Old 03-15-2015, 02:13 AM   #6
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Should've got the original Raceseng part instead of the copycat.
Originally Posted by humfrz
I'm old and lazy
The Following 2 Users Say Thank You to Clipdat For This Useful Post:
Koa (03-15-2015), Liquid6 (03-16-2015)
Old 03-15-2015, 02:18 AM   #7
edeekeos
edeekeos's Avatar
Yeah I'm starting to wonder that. I just like the design of the Nameless more.
Old 03-15-2015, 01:25 PM   #8
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Oh boy...
Old 03-15-2015, 01:41 PM   #9
edeekeos
edeekeos's Avatar
Old 03-15-2015, 02:01 PM   #10
weederr33
weederr33's Avatar
I haven't installed mine yet, and I'm hoping not to deal with this problem
Old 03-15-2015, 02:28 PM   #11
MrBlaze-65
Drives: 2014 Subaru BRZ
basically these parts mate up to flat surfaces, as long as the metal isn't bent or warped which it shouldn't be unless in shipping it got messed up. You're plate should be fine. Now what actually helps in the liquid tight sealing is your o-ring, so if it has a defect all you need is a replacement. Now if it's not getting a good uniform squeeze then it doesn't matter how good or bad your o-ring is because it won't be sealing.
MrBlaze-65 is offline   Reply With Quote
Old 03-15-2015, 02:53 PM   #12
Koa
Raceseng's offering comes with a Viton O-ring.. consistent quality. If Nameless has a like-quality O ring in their setup, it most likely is user installer error. Are you 100% cleaning the mating surfaces from all gasket goop, and applying RTV sealant as per installation specs?
Pics would help.
Old 03-15-2015, 03:39 PM   #13
weederr33
weederr33's Avatar
Mine didn't come with RTB sealant. Just the O-Ring. TBH, I have no idea if the ring is like-quality of Raceseng's.
Old 03-16-2015, 10:57 AM   #14
Calum
That Guy
Post a picture of your O ring. I could likely tell you if its a viton by the color/condition. Viton is what I hope these kits come with.
Nameless Muffled Axleback, any problems? taylorsankey Engine, Exhaust, Transmission 20 04-07-2015 03:46 PM
Nameless Performance Cam Plate 00NissanNinja Engine, Exhaust, Transmission 1 11-20-2014 09:19 PM
Transmission problems, oil leaks and detonation problems.. turboviper Issues | Warranty | Recalls / TSB 4 06-18-2014 05:01 PM
Nameless releasing Sensor Plate for Innovate Motorsports BRZ/FRS/GT86 Twin Screw xjohnx Forced Induction 24 07-20-2013 04:26 PM
[For Sale] Rho-plate Tow Hook Mounted License Plate rack pizzahead20 Canada Classifieds 0 08-23-2012 01:06 AM
