Old 03-10-2015, 09:48 PM   #1
Tyrant
Drives: 2014 BRZ Satin White Pearl Limited
Can't activate FC on OFT
So i picked up a OFT about ago and had little trouble installing it. Needless to say, I was quite satisfied with preloaded stage 1 map. My trouble began when I tried to set the delta for LC. I found my calibration ID(B00C) on OFM and added the v2.0 XML definition to Romraider along with the beta v2.0 (stg 1 B00C bin), however the ALPHA table for LC and FFS was not available. I tried adding other definitions and looking through other bins including those from the v1.59 bins and XML to no avail. Anyone able to shed of light into what I'm doing wrong?
Tyrant is offline   Reply With Quote
Old 03-10-2015, 10:45 PM   #2
steve99
make sure your using the definitions that come with the OFT tune pack, don't use defs from github with OFT tunes. They don't have tables defs for the rom patch for lc/ffs and you can brick your ecu due calid adjustments in oft roms.
if still no go maybe those roms don't have the patch, i know the latest D00C roms don't have it yet.
Old 03-10-2015, 11:24 PM   #3
Tyrant
i used the xml definitions that came with the v2.0 download. i got it via this link after some forum surfing. http://openflashtablet.com/page33/pr...ads/index.html
i also tried the xml and bin of 1.59 and that didn't show up either. I couldn't find any tutorials of how to use romraider for the ft86 platform, however I did find one for the mx5 on Shiv's youtube channel. I added the xml files using the definition manager and proceeded to use the bins that came with that same pack. This is the correct method right? the wrong method method in which you, @steve99, were referring to is the "get ecu definition option" right?
Old 03-10-2015, 11:58 PM   #4
steve99
sound like that rom does not have lc/ffs patches
email or call the guys at openflash
dont pm shiv does not work his box get full.
Old 03-11-2015, 06:53 PM   #5
Tyrant
sounds like it's my last option. i used the contact option on the OFT site. Is there a faster way?
Old 03-16-2015, 06:01 PM   #6
Tyrant
So after almost a week after I emailed OFT support (they havn't gotten back to be after asking for some info including my calibtration ID) it looks like the download page on OFT's page was updated. The bin/xml I was using before was version 2.0. That changed to 2.063 today. I just tried to the new definitions with the included bin and the FFS/LC was available. So it looks like you were right, @steve99, the v2.0 wasn't patched. Whether I was directly responsible for the update or not, i'm still happy that everything worked out.
The Following User Says Thank You to Tyrant For This Useful Post:
steve99 (03-16-2015)
How to activate brz limited alarm Lee358 DIY (Do-It-Yourself) Guides 129 05-17-2024 09:21 AM
Don't forget to activate your alarm! BRZnut BRZ First-Gen (2012+) — General Topics 49 04-28-2016 02:23 PM
Activate your alarm!! engee NY / NJ / CT / PA 10 06-09-2015 01:45 PM
The All Whiteline Thread! Activate More Grip! RallySport Direct Brakes, Suspension, Chassis 4 06-12-2013 06:40 PM
