Old 03-05-2015, 03:21 AM   #1
jaorocks1
jaorocks1's Avatar
Drives: 92 Prelude
Inlet Tube Impressions? #Worth?
For $120-200 the inlet tube + Drop in filter combo looks like a good bang for the buck. My question is looking at several dynos of drop in filter and inlet tubes it looks like the inlet tubes hardly make any improvements at all on N/A cars, most of the gains coming from the drop in filter.
Anybody notice any change in engine response/torque/hp when installing just the inlet tube? Was it worth the purchase?
I've heard the supertek heat soaking the engine, as well as mishimoto claiming the resonator adds horsepower.... Is this with all inlet tubes?
jaorocks1 is offline   Reply With Quote
Old 03-05-2015, 08:13 AM   #2
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
I think it cleans up the engine bay alot and adds a few hp. I would recommended it. Less than $100 total. Pm Genome Tuning and you can get a resonator plug from him for around $10.
Intake Tube
http://www.deporacing.us/shop/fr-s-b...s-intake-hose/
K&N Filter
http://www.ebay.com/itm/K-N-K-N-Air-...157080&vxp=mtr
malubawla is offline   Reply With Quote
Old 03-05-2015, 08:34 AM   #3
rlpaul
Drives: point A to point C. Screw point B!
Take the HP gains with a grain of salt. It's theoretically smoother airflow, which should translate to better performance. The GrimmSpeed intake thread actually has some good info on inlet tubes from their initial testing.
I think its worth doing just to get rid of all the sound generator junk in the engine bay. It takes up a surprising amount of space. So even if HP gains are negligible, you get space to work around the engine, plus a bit of weight savings as well (granted, also negligible).
rlpaul is offline   Reply With Quote
The Following User Says Thank You to rlpaul For This Useful Post:
BRZeer (01-28-2024)
Old 03-05-2015, 12:08 PM   #4
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
It adds a bit to the sound. I didn't notice any power difference. There are a couple for sale used in the classified section. Go that way if you're not sure.
JohnJuan is offline   Reply With Quote
Old 03-05-2015, 12:58 PM   #5
swarb
It makes ~one hp, and a little more noise. $70 shipped isn't so bad. I'd do it if I wanted to remove the sound tube. Too bad it's gloss black, I don't think it matches too well.
Old 03-05-2015, 01:04 PM   #6
TatharPallan
Drives: 2015 Subaru Blue Series - Pearl
it cleans the engine bay a lot. as far as performance gains there isn't much. I'm at work so i don't have the pictures available to post.
http://blog.perrinperformance.com/fr-sbrz-inlet-hose/
2015 BRZ Series.Blue CWP (K1X) - JDL UEL Header, 3" JDL Res FP, 3" JDL OP, 3" Perrin Res Cat back, 3" Perrin BigMAF Intake/Inlet tube, Perrin Light Weight Pulleys (AC, Water Pump, Crank) - Moto-East FFK - E85 Tuned by HRI - ECUTEK - Eibach Pro-Kit Lowering Springs
TatharPallan is offline   Reply With Quote
Old 03-05-2015, 01:58 PM   #7
jaorocks1
jaorocks1's Avatar
Drives: 92 Prelude
Anybody know anything about the Supertek heat soak issue? Is that something that's universal with these inlet tubes?http://www.ft86club.com/forums/showt...t=54710&page=3
Old 03-05-2015, 03:10 PM   #8
kbye
kbye's Avatar
Drives: 2014 FR-S
I am not surprised, seeing as metal retains heat better than plastic. However I am not overly worried as many companies have used aluminum in their intake design. Grimmspeed, for example. If you are concerned, you could go with a silicon inlet instead, but they don't have the bling factor.
FWIW I bought the supertek intake over the weekend, so I'll see if I can do some controlled testing vs. stock.
kbye is offline   Reply With Quote
Old 03-05-2015, 05:35 PM   #9
jaorocks1
jaorocks1's Avatar
Drives: 92 Prelude
Ahh didn't realize they were cast aluminum. What do you think about the resonator adding more HP theory? Lol
Old 03-05-2015, 05:37 PM   #10
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I think it's worth it. Of course, I only got one for looks. I didn't really care about the potential performance gains.
Old 03-06-2015, 08:41 AM   #11
evil_1998
evil_1998's Avatar
Drives: GT86
In winter it's great. It pulls harder & a slight more induction noise. Should be a bit more flow than stock. But in summer, I think the metal generates more heat especially when idle. However if you are constantly moving & getting air, not too bad. For the money, its quite good value.
PROJECTGT86
evil_1998 is offline   Reply With Quote
Old 03-20-2015, 10:02 AM   #12
Mishimoto
Drives: 2013 Subaru BRZ
Although more power can be obtained from other modifications, adding an inlet tube can certainly net a few HP and cleans up the engine bay quite a bit. We performed a ton of testing on our inlet tube to evaluate just how much power is gained when using this component with the resonator, without the resonator, as well as with an aftermarket drop-in filter.
We saw around 3whp/2wtq gains with our induction hose installed and the resonator connected. Tossing in an aftermarket filter brought gains to 6whp/3wtq. Our full report is linked below.
http://lib.store.yahoo.net/lib/yhst-...ing-Report.pdf
If you are looking to improve the appearance of your engine bay and add a few ponies, the inlet tube is a nice upgrade.
If you are looking for greater gains from the intake system, a full replacement system is probably a better option for you.
Thanks!
-John
Mishimoto is offline   Reply With Quote
The Following 3 Users Say Thank You to Mishimoto For This Useful Post:
BigHugeFatGuy (10-20-2019), BlackieChanz (07-25-2018), JohnJuan (03-20-2015)
Old 03-20-2015, 10:12 PM   #13
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Normally this is something we'd be a little skeptical about, but on any of our tunes, adding this silicone inlet hose nets a solid and repeatable ~2whp and smooths out the curve ever so slightly. Not a bad bang for your buck, and combined with a high flow filter in the stock airbox, makes for one of the best intake options on an NA car we've tested. If it were me, I'd get the inlet tube and a high flow filter and call it a day for intake mods.
Sincerely,
Zach
The Following 10 Users Say Thank You to DeliciousTuning For This Useful Post:
86geek (03-26-2016), BigHugeFatGuy (10-20-2019), cmiovino (05-01-2024), JoeBoxer (06-24-2015), Koa (03-23-2015), mgarcia707 (08-23-2018), MrSkubi (12-01-2018), steve99 (03-21-2015), TofuJoe (07-21-2015), wparsons (03-21-2015)
Old 03-22-2015, 09:23 AM   #14
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
i did it just to clean up the engine bay and get rid of the sound tube.
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
wtb: sound tube delete inlet tube Jimmy817 Engine, Exhaust, Bolt-Ons 1 12-21-2014 09:15 AM
Air inlet tube mod after drop in filter mod review. Worth it? johnnyfast11 Engine, Exhaust, Transmission 5 04-21-2014 11:33 PM
SuperTek Air Inlet Tube $80 retrosmiths Engine, Exhaust, Bolt-Ons 21 04-13-2014 03:20 AM
Perrin inlet tube xanth123 Northwest 3 11-30-2013 07:23 PM
WTB: Perrin Inlet Tube Gilman711 Engine, Exhaust, Bolt-Ons 2 05-28-2013 12:11 PM
