Old 02-28-2015, 04:27 PM   #1
Ornelas66
Drives: 2015 Scion FRS
Any recommendations which system to running E85
I am trying to decide which system I should use to run E85 fuel. I was thinking of going with a flex fuel system incase I run out of E85 and pump 91 in the tank. However, I forsee in the future turning my NA FRS into a forced Induction system. Any advice on which system will grow with my needs. Any pros or cons with one system over another? Thanks in advance for any advice.
Ornelas66 is offline   Reply With Quote
Old 02-28-2015, 05:58 PM   #2
steve99
You can run E85 with a tune on any tuning system , but if you want true flexfuel system with intergrated flex fuel sensor Ecutek is the only system that does flex fuel.
cons it costs more due cost of flex fuel sensor and install.
Ornelas66 (02-28-2015)
e85, ecutek, flex fuel system, oft
FR-S PARTS CATALOG SYSTEM IS UP AND RUNNING TPO Scion FR-S / Toyota 86 GT86 General Forum 96 06-03-2015 05:16 PM
Any recommendations for a HID H7 kit? archangel AUSTRALIA 0 10-26-2014 06:17 PM
Hid i d recommendations? Vincenttam Cosmetic Modification (Interior/Exterior/Lighting) 12 11-06-2013 01:26 AM
PDR Recommendations in NY or CT TommyFive NY / NJ / CT / PA 6 09-10-2013 03:48 PM
Be Spoke system/ BRZ system navigation swap Mrqb22 Electronics | Audio | NAV | Infotainment 4 09-27-2012 05:48 PM
